宏想120G 瑞昱RTS5733 怪问题
Quietquasar
2026-8-24 09:43
宏想120G 瑞昱RTS5733 双闪存 HJKWH64GAIMJ8I
使用过程中蓝屏。上电不识别,重启似乎直接进入rom模式,能识别到REALTEK_RL6531
Realtek SSD flash id输出,仅Bank04有闪存信息。请问这是只识别到一块闪存吗?是线路故障或虚焊吗?
v0.17a
Drive: 2(ATA)
OS: 10.0 build 19045
ATA: SmartEnable failed! Error: 0x51
Model: REALTEK_RL6531
Fw : 3.AAE
Size : 1 MB [0.0 GB]
FwStr: [REALTEK_RL6531]
Controller: Realtek RTS5733
ATA: Get FWI failed! Error: 0x51
Bank00: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank01: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank02: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank03: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank04: 0xad,0x7e,0x28,0x33,0x0,0xa2,0xad,0x7e - Hynix 3dv5-96L TLC 16k 512Gb/CE 512Gb/die
Bank05: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank06: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank07: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank08: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank09: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank10: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank11: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank12: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank13: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank14: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Bank15: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff -
Flash CE Mask : [++++-+++ ++++++++]
Fabric Bad block list (bank0 only):
ATA: Get BBEC failed! Error: 0x51
Ch0CE0: =0
Later Bad block list (bank0 only):
Ch0CE0: =0
Bank0 BB (Fabric+Later): 0 (0+0)
