标题: 有没有大神知道这芯片是多少球的呀 [打印本页]
作者: 艾心晴愿    时间: 2025-6-7 13:13
有没有大神知道这芯片是多少球的呀。
这是百度搜的。EDFP264A2PB-JD-F-D Technical Details[td]
TYPE
DESCRIPTION
Clock Frequency:
933 MHz
Operating Temperature:
-30°C ~ 85°C (TA)
Category:
Integrated Circuits (ICs)
Memory Memory
Memory Interface:
Parallel
Memory Organization:
384M x 64
Memory Type:
Volatile
Standard Package:
1,190
Memory Size:
24Gbit
Technology:
SDRAM - Mobile LPDDR3
Voltage - Supply:
1.14V ~ 1.95V
Package:
Tray
Memory Format:
DRAM
Base Product Number:
EDFP264
Moisture Sensitivity Level (MSL):
3 (168 Hours
作者: 冰封冷雁    时间: 2025-6-8 00:34
直接刮锡浆
