R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID 0VB001
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDB0 16 17 18 19 20 21 22 23
[2 ] Data line toggle (GUI) : FAIL
Error ID 0VB023
failing bit : MDB0 0 1 2 3 16 17 18 19 ...
[3 ] RW page (GUI) : FAIL
Error ID 0VB025
failing bit : MDB0 0 1 2 3 16 17 19 20 ...
[4 ] RW channel (GUI) : FAIL
Error ID 0VB028
failing bit : MDB0 0 1 2 3 18 19 20 21 ...
[5 ] Data mask : FAIL
Error ID 0VB006
[6 ] Macro + Micro8x2 tiling read : FAIL
Error ID 0VC006
[8 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID 0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
failing bit : MDB0 19 20 21
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
failing bit : MDB0 19 20 21 22
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
failing bit : MDB0 17 19 20 21 22
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
failing bit : MDB0 1 2 3 19 20 21 22 23
[9 ] Line slopes/dir/P/solid : FAIL
Error ID 0TR010
error : R072A.9 not found
error : R073A.9 not found
error : R075A.9 not found
Failure detected.
