0025
- Operation failure of the CR
1. The CR was stopped by;
- Obstacles such as jammed paper
- Overload of the mechanism
- Interfere with the ink system
- Failed to read the CR motor encoder
2. The timing belt become loosened or jumping
3. Contamination of the CR encoder scale
4. Damage or skew of the CR encoder FFC
5. Failure of the CR motor
6. Failure of the main board
0044
- The PF motor did not run or obstacles exist in the paper path
1. Overload of the paper feed mechanism
2. The PF timing belt become frayed, jumping,
or the wheel train of paper feed mechanism
is disengaged or its tooth is broken
- Failed to read the PF motor encoder
3. Contamination of the PF encoder scale
4. Disconnection, break, skew or damage of the PF encoder FFC
5. Failure of the PF encoder sensor
6. Failure of the PF motor (the lead wire is broken
or the connector is disconnected)
7. Failure of the main board
