标题: 联想V460不通电即不触发小修 [打印本页]
作者: u1578099    时间: 2025-1-2 13:13
标题: 联想V460不通电即不触发小修
品牌:LENOVO
型号:V460 I3 380独显
板号:LA46 MB DIS(纬创资通)
故障现象:插上适配器无待机电流,按下开关不通电!
故障分析:针对I3 380的设计来判断,待机时无电流也是正常的,但触发无任何反应,即没亮灯指示!说明前面没有起来:
解决过程:首先查保护隔离电路:如图1:
从适配器接口4 5 6脚出来一路经过滤波电容、防静电二极管,到达带有体二极客的场效应管U50的S极,然后从D极输出20V电压,实测D极为19.36V;由此说明公共点AD+正常!
然后AD+再过U47、R407产生DCBATOUT ,最后过U49产生BT+,实测DCBATOUT为19.36V,BT+为0.45V;
DCBATOUT做为待机芯片TPS51123的主供电,由此芯片产生3D3V_AUX_S5、5V_AUX_S5、5V_PWR、3D3V_PWR四个电压,前两个是待机便有,而后两个是触发后才有;实测TPS51123的主供电VIN有19.36V,EN0有5.06V,VREF为0.98V、VREG3有3.3V,VREG5有5V,ENC为0V、5V_PWR与3D3V_PWR没出来!
在这里要说明下,ENC为5V_PWR、3D3V_PWR此两个电压的开启控制信号脚,应该为高电平!而实测确为低电平,查其来源:如图4:
实测S5_ENABLE输出电压为0V,那它为什么没有电压呢?查EC的供电、时钟、复位;供电正常、复位也正常,唯独测不到时钟,如图5:
weibo.com/ttarticle/p/show?id=2309405118332578955448
weibo.com/ttarticle/p/show?id=2309405118333262626882
weibo.com/ttarticle/p/show?id=2309405118334269259873
weibo.com/ttarticle/p/show?id=2309405118335049400640
weibo.com/ttarticle/p/show?id=2309405118335816958196
weibo.com/ttarticle/p/show?id=2309405118336320274466
weibo.com/ttarticle/p/show?id=2309405118336802619568
weibo.com/ttarticle/p/show?id=2309405118337494679567
weibo.com/ttarticle/p/show?id=2309405118338048327688
weibo.com/ttarticle/p/show?id=2309405118338593587469
weibo.com/ttarticle/p/show?id=2309405118339008823540
weibo.com/ttarticle/p/show?id=2309405118339604152353
weibo.com/ttarticle/p/show?id=2309405118340451663961
weibo.com/ttarticle/p/show?id=2309405118341122752774
weibo.com/ttarticle/p/show?id=2309405118342003556432
weibo.com/ttarticle/p/show?id=2309405118330536329479
weibo.com/ttarticle/p/show?id=2309405118330603438279
weibo.com/ttarticle/p/show?id=2309405118330838056985
weibo.com/ttarticle/p/show?id=2309405118330951565410
weibo.com/ttarticle/p/show?id=2309405118331228389469
weibo.com/ttarticle/p/show?id=2309405118331383578910
weibo.com/ttarticle/p/show?id=2309405118331513602378
weibo.com/ttarticle/p/show?id=2309405118346558570608
weibo.com/ttarticle/p/show?id=2309405118346663166002
weibo.com/ttarticle/p/show?id=2309405118346730274834
weibo.com/ttarticle/p/show?id=2309405118346801578030
weibo.com/ttarticle/p/show?id=2309405118346868686875
