标题: AMI BIOS 厂商信息配置工具 AMIDEWINx64_5.27.00.0003 [打印本页]
作者: u1577704    时间: 2024-12-30 18:02
命令行工具,无GUI
AMIDEWINx64 回车查看帮助信息
AMIDEWINx64 /DMS CFG.ini 导出当前配置到 CFG.ini
“<handle #>”即注释里面“Type #”的“#”,例如:
AMIDEWINx64 /BMH 2 查看主板制造商
不输入自定义信息默认Read读取模式。
|        AMI Desktop Management Interface Edit Utility v5.27.00.0003        |
|      Copyright (c) 1985-2020, American Megatrends International LLC.      |
|         All rights reserved. Subject to AMI licensing agreement.          |
| Commands:        |
|       /ALL  [FileName]  Output SMBIOS string to screen/file.              |
|       /DMS  [FileName]  Create configuration file.                        |
|   /DUMPALL  [FileName]  Output all SMBIOS data to screen/file.            |
|      /DUMP  # [#] ...   Read Type # data.                                 |
| Options:        |
|       /IVN  ["String"]  Read/Write BIOS vendor name in Type 0.            |
|        /IV  ["String"]  Read/Write BIOS version in Type 0.                |
|        /ID  ["String"]  Read/Write BIOS release date in Type 0.           |
|        /SM  ["String"]  Read/Write System manufacture in Type 1.          |
|        /SP  ["String"]  Read/Write System product in Type 1.              |
|        /SV  ["String"]  Read/Write System version in Type 1.              |
|        /SS  ["String"]  Read/Write System Serial number in Type 1.        |
|        /SU  [16 Bytes]  Read/Write System UUID in Type 1.                 |
|        /SU  AUTO Generates system UUID automatically and update Type 1.   |
|        /SK  ["String"]  Read/Write System SKU number in Type 1.           |
|        /SF  ["String"]  Read/Write System family in Type 1.               |
|        /BM  ["String"]  Read/Write Baseboard manufacture in Type 2.       |
|        /BP  ["String"]  Read/Write Baseboard product in Type 2.           |
|        /BV  ["String"]  Read/Write Baseboard version in Type 2.           |
|        /BS  ["String"]  Read/Write Baseboard Serial number in Type 2.     |
|        /BT  ["String"]  Read/Write Baseboard Asset Tag  in Type 2.        |
|       /BLC  ["String"]  Read/Write Baseboard Loc. in Chassis  in Type 2.  |
|       /BMH  <handle #>  ["String"]                                        |
|       /BPH  <handle #>  ["String"]                                        |
|       /BVH  <handle #>  ["String"]                                        |
|       /BSH  <handle #>  ["String"]                                        |
|       /BTH  <handle #>  ["String"]                                        |
|      /BLCH  <handle #>  ["String"]                                        |
|        /CM  ["String"]  Read/Write Chassis manufacture in Type 3.         |
|        /CT  [8 Bits]    Read/Write Chassis type in Type 3.                |
|        /CV  ["String"]  Read/Write Chassis version in Type 3.             |
|        /CS  ["String"]  Read/Write Chassis Serial number in Type 3.       |
|        /CA  ["String"]  Read/Write Chassis Tag number in Type 3.          |
|        /CO  [32 Bits]   Read/Write Chassis OEM-defined value in Type 3.   |
|        /CH  [8 Bits]    Read/Write Chassis Height in Type 3.              |
|       /CPC  [8 Bits]    Read/Write Chassis Power Cords number in Type 3.  |
|       /CSK  ["String"]  Read/Write Chassis SKU number in Type 3.          |
|       /CMH  <handle #>  ["String"]                                        |
|       /CTH  <handle #>  [8 bits]                                          |
|       /CVH  <handle #>  ["String"]                                        |
|       /CSH  <handle #>  ["String"]                                        |
|       /CAH  <handle #>  ["String"]                                        |
|       /COH  <handle #>  [32 bits]                                         |
|       /CHH  <handle #>  [8 bits]                                          |
|      /CPCH  <handle #>  [8 bits]                                          |
|      /CSKH  <handle #>  ["String"]                                        |
|       /PSN  ["String"]  Read/Write Processor serial number in Type 4.     |
|       /PAT  ["String"]  Read/Write Processor asset tag in Type 4.         |
|       /PPN  ["String"]  Read/Write Processor part number in Type 4.       |
|      /PSNH  <handle #>  ["String"]                                        |
|      /PATH  <handle #>  ["String"]                                        |
|      /PPNH  <handle #>  ["String"]                                        |
|        /OS  [<Number> <"String">]                                         |
|             Read/Write OEM string in Type 11.                             |
|       /SCO  [<Number> <"String">]                                         |
|             Read/Write Sys. Configuration Op. in Type 12.                 |
|       /PBL  <handle #>  ["String"]                                        |
|             Read/Write Port. Battery Location in Type 22.                 |
|       /PBM  <handle #>  ["String"]                                        |
|             Read/Write Port. Battery Manufacturer in Type 22.             |
|       /PBD  <handle #>  ["String"]                                        |
|             Read/Write Port. Battery ManuDate in Type 22.                 |
|       /PBS  <handle #>  ["String"]                                        |
|             Read/Write Port. Battery Serial Number in Type 22.            |
|       /PBN  <handle #>  ["String"]                                        |
|             Read/Write Port. Battery Device Name in Type 22.              |
|      /PBCH  <handle #>  [8 Bits]                                          |
|             Read/Write Port. Battery Device Chemistry in Type 22.         |
|      /PBCA  <handle #>  [16 Bits]                                         |
|             Read/Write Port. Battery Design Capacity in Type 22.          |
|       /PBV  <handle #>  [16 Bits]                                         |
|             Read/Write Port. Battery Design Voltage in Type 22.           |
|      /PBSV  <handle #>  ["String"]                                        |
|             Read/Write Port. Battery SBDS Ver. Num. in Type 22.           |
|       /PBE  <handle #>  [8 Bits]                                          |
|             Read/Write Port. Battery Maxmum Error in Type 22.             |
|      /PBSN  <handle #>  [16 Bits]                                         |
|             Read/Write Port. Battery in SBDS Ser. Num. in Type 22.        |
|      /PBSD  <handle #>  [16 Bits]                                         |
|             Read/Write Port. Battery in SBDS Manu. Date. in Type 22.      |
|      /PBSC  <handle #>  ["String"]                                        |
|             Read/Write Port. Battery in SBDS Dev. Chem. in Type 22.       |
|      /PBCM  <handle #>  [8 Bits]                                          |
|             Read/Write Port. Battery in Design Cap Multi in Type 22.      |
|       /PBO  <handle #>  [32 Bits]                                         |
|             Read/Write Por. Bat. in OEM-Specific Type 22.                 |
|        /PU  <handle #>  [8 Bits]                                          |
|             Read/Write Power supply unit group in Type 39.                |
|        /PL  <handle #>  ["String"]                                        |
|             Read/Write Power supply location in Type 39.                  |
|        /PD  <handle #>  ["String"]                                        |
|             Read/Write Power supply device name in Type 39.               |
|        /PM  <handle #>  ["String"]                                        |
|             Read/Write Power supply manufacturer in Type 39.              |
|        /PS  <handle #>  ["String"]                                        |
|             Read/Write Power supply serial number in Type 39.             |
|        /PT  <handle #>  ["String"]                                        |
|             Read/Write Power supply asset tag number in Type 39.          |
|        /PN  <handle #>  ["String"]                                        |
|             Read/Write Power supply model part number in Type 39.         |
|        /PR  <handle #>  ["String"]                                        |
|             Read/Write Power supply revision level in Type 39.            |
|        /PP  <handle #>  [16 Bits]                                         |
|             Read/Write Power supply max power capacity in Type 39.        |
|        /PC  <handle #> [16 Bits]                                          |
|             Read/Write Power supply characteristics in Type 39.           |
|       /PVH  <handle #>  [16 Bits]                                         |
|             Read/Write Power supply voltage probe handle in Type 39.      |
|       /PDH  <handle #>  [16 Bits]                                         |
|             Read/Write Power supply cooling dev. handle in Type 39.       |
|       /PCH  <handle #>  [16 Bits]                                         |
|             Read/Write Power supply current probe handle in Type 39.      |
| 1. The expression enclosed by <> means it is a mandatory field.           |
| 2. The expression enclosed by [] means it is an optional field.           |
| 3. A command without parameter means it is a read command.                |
| 4. A command with necessary parameter means it is a write command.        |
| 5. The format of BIOS release date is "mm/dd/yyyy".                       |
AMIDEWINx64_5.27.00.0003.7z
128.57 KB, 下载次数: 57, 下载积分: 下载分 -2 分, 下载 1 次
作者: ytfqifwamy    时间: 2025-2-11 15:37
这是好工具哦,,,
作者: 327557513    时间: 2025-8-18 19:03
刚好需要
作者: 年轻的老裴    时间: 3 天前
正需要这个
