戴尔Vostro_3900_3800_3902_A16主板官方bios 含自己主板的提取备份
u1482997
2024-12-10 12:00
win11下可执行文件,不会使用。
| AMI Firmware Update Utility v3.07.01.Dell |
| Copyright (C)2014 American Megatrends Inc. All Rights Reserved. |
| Usage: AFUWINx64.EXE <ROM File Name> [Option 1] [Option 2]... |
| or |
| AFUWINx64.EXE <Input or Output File Name> <Command> |
| or |
| AFUWINx64.EXE <Command> |
| Commands: |
| /O - Save current ROM image to file |
| /U - Display ROM File's ROMID |
| /S - Refer to Options: /S |
| /D - Verification test of given ROM File without flashing BIOS. |
| /A - Refer to Options: /A |
| /OAD - Refer to Options: /OAD |
| /CLNEVNLOG - Refer to Options: /CLNEVNLOG |
| Options: |
| /CMD: - Send special command to BIOS. /CMD:{xxx} |
| /MEUL: - Program ME Entire Firmware Block, which supports |
| Production.BIN and PreProduction.BIN files. |
| /Q - Silent execution |
| /X - Don't Check ROM ID |
| /CAF - Compare ROM file's data with Systems is different or |
| not, if not then cancel related update. |
| /S - Display current system's ROMID |
| /JBC - Don't Check AC adapter and battery |
| /HOLEOUT: - Save specific ROM Hole according to RomHole GUID. |
| NewRomHole1.BIN /HOLEOUT:GUID |
| /SP - Preserve Setup setting. |
| /R - Preserve ALL SMBIOS structure during programming |
| /Rn - Preserve SMBIOS type N during programming(n=0-255) |
| /B - Program Boot Block |
| /P - Program Main BIOS |
| /N - Program NVRAM |
| /K - Program all non-critical blocks. |
| /Kn - Program n'th non-critical block(n=0-15). |
| /HOLE: - Update specific ROM Hole according to RomHole GUID. |
| NewRomHole1.BIN /HOLE:GUID |
| /L - Program all ROM Holes. |
| /Ln - Program n'th ROM Hole only(n=0-15). |
| /ECUF - Update EC BIOS when newer version is detected. |
| /E - Program Embedded Controller Block |
| /ME - Program ME Entire Firmware Block. |
| /FDR - Flash Flash-Descriptor Region. |
| /MER - Flash Entire ME Region. |
| /MEUF - Program ME Ignition Firmware Block. |
| /A - Oem Activation file |
| /OAD - Delete Oem Activation key |
| /CLNEVNLOG - Clear Event Log. |
| /CAPSULE - Override Secure Flash policy to Capsule |
| /RECOVERY - Override Secure Flash policy to Recovery |
| /EC - Program Embedded Controller Block. (Flash Type) |
| /REBOOT - Reboot after programming. |
| /SHUTDOWN - Shutdown after programming. |
Vostro_3900_3800_3902_A16.7z
2024-12-10 11:59 上传
点击文件名下载附件
下载积分: 下载分 -2 分
6.04 MB, 下载次数: 16, 下载积分: 下载分 -2 分
u1498737
2025-2-22 20:35
非常需要。。。。。。。。。。。。。。。。。
