标题: Need Help RM1135 and Micron B37R [打印本页] 作者: gu1571268 时间: 2024-11-14 04:57 标题: Need Help RM1135 and Micron B37R Hello!
Please tell me where I can download files for Micron B37R and RM1135/RTS5735/RL6643 controller?
Thank you.
作者: gu1571268 时间: 2024-11-14 10:28
https://www.chinafix.com/thread-1345115-1-1.html
This flasher didn't have files for Micron B37R memory ((
Although this memory was in the description.作者: WCC0044 时间: 2024-12-27 14:45
Thank you Thank you作者: XHqiao 时间: 2024-12-31 09:31
不会外语还看不明白了作者: van7777 时间: 2024-12-31 17:23
需要安裝了 Micron B37R 記憶體的 SSD 韌體的協助作者: van7777 时间: 2024-12-31 18:23
This is the SSD that needs to be flashed. The inscriptions on the memory chips (4 pieces) - 29FSRHB3BEDTM3
