MATS测试4070TI显卡用那个模式?
u1553643
2024-5-29 18:41
本人萌新,MATS测试4070TI显卡用那个模式?UEFI和LEGACY模式测试的结果不一样啊,UEFI模式无法通过,但是用LEGACY模式就能通过。到底该看那个结果?
这个是UEFI模式的结果: GPU 0 [01:00.0] dev.sub 0.0 ----------------------------------------
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x2782
PDI : 0xf2a81c945ce7d7fe
Raw ECID : 0x011fc20000000004c0c40de1
Raw ECID (GHS) : 0x17804c0c40c00000008fe0200
ECID : TSMC-U1C343-08_x-4_y8
Device Id : AD104
Revision : a1
Sub Revision : 15
NV Base : 0xa2000000
FB Base : 0x90000000
IRQ : 11
ERROR: bp @ <fileid:0x0001f0>:2702
ERROR: ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] ------------------------- BEGIN ASSERT INFO DUMP -------------------------
[ ] --->reghalconst.jse
[ ] Preprocessing reghalconst.jse.
[ ] Successfully opened /home/455.127/reghalconst.jse
[ ] Compiling reghalconst.jse.
[ ] Compiled reghalconst.jse, pScript = 0x0x10c27de0.
[ ] Executing reghalconst.jse.
[ ] reghalinternal.jse does not exist.
[ ] <---reghalconst.jse
[ ] pvstest.jse does not exist.
[ ] <gputest.jse
[ ] Done parsing args
[ ] >base.spc
[ ] Preprocessing base.spc.
[ ] Successfully opened /home/455.127/base.spc
[ ] Compiling base.spc.
[ ] Compiled base.spc, pScript = 0x0x10831250.
[ ] Executing base.spc.
[ ] <base.spc
[ ] Command Line : gputest.js -no_gold -test 275
[ ] CPU
[ ] Arch : x86_64
[ ] Name : Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz
[ ] Cores : 6
[ ] Version
[ ] MODS : 520.112
[ ] System
[ ] OperatingSystem: Linux (x86_64)
[ ] Kernel : 5.9.1-gentoo-x86_64
[ ] KernelDriver : 4.00
[ ] SBIOS Version : 1.C0
[ ] SBIOS Date : 10/20/2022
[ ] HostName : tinylinux
[ ] Available RAM : 31717/32186 MB (Free/Size)
[ ] NUMA Node 0 RAM: 31717/32186 MB (Free/Size)
[ ] Hypervisor : No
[ ] Sysmem page size is 4 KB
[ ] Smbios version [0x208] is not supported
[ ] Failed to Read system UUID, this requires root permissions to run
[ ] Sys-uuid :
[ ] Failed to Read Hdisk Serial num, this requires root permissions to run
[ ] HDD-Serno :
[ ] Turning off register exclusion regions.
[ ] >boards.jse
[ ] Preprocessing boards.jse.
[ ] Successfully opened /home/455.127/boards.jse
[ ] Compiling boards.jse.
[ ] Compiled boards.jse, pScript = 0x0x10761660.
[ ] Executing boards.jse.
[ ] <boards.jse
[ ] CreateNvLinkLibInterface : Creating NvLink library interface NvLinkLibIfUser
[ ] CreateAllDevInterfaces : Created NvLink device interface NvSwitchDevIf
[ ] CreateAllDevInterfaces : Created NvLink device interface NvGpuDevIf
[ ] Warning: Can't find Pci device with class code 0x68000, index 0
[ ] Find NvSwitch ports
[ ] -------Finish NvSwitch detection-----
[ ] Physical Graphics controller at 0000:01:00.0
[ ] reg virtual base = 0x7f9a5dffe000
[ ] IOVA enabled
[ ] Detected 47 sysmem address bits for chip id 0xd04 at 0000:01:00.0, IOVA enabled
[ ] BAR0 base = 0x0_A2000000,
size = 0x01000000
[ ] BAR1 base = 0x0_90000000,
size = 0x10000000
[ ] BAR2 base = 0x0_A0000000,
size = 0x02000000
[ ] Vendor ID = 0x10DE
[ ] Device ID = 0x2782
[ ] Chip ID = 0x00000194
[ ] [0000:01:00.0] cap id 0x5 found at offs 0x68
[ ] [0000:01:00.0] cap id 0x11 not found
[ ] [0000:01:00.0] cap id 0x10 found at offs 0x78
[ ] [0000:01:00.0] extended cap id 0x1e found at offs 0x0258
[ ] Register manual file ad104_ref.txt not found
[ ] Warning: Can't find Pci device with class code 0x30000, index 1
[ ] Warning: Can't find Pci device with class code 0x30200, index 0
[ ] Found Test Devices :
[ ] GPU 0 [01:00.0]
[ ] Find bridge ports
[ ] [0000:00:01.0] bridge sec=01 sub=01 vendor=8086 devid=1901 uniq_link_poll=true
[ ] [0000:00:1b.0] bridge sec=02 sub=02 vendor=8086 devid=a340 uniq_link_poll=false
[ ] Warning: Can't find Pci device with class code 0x60400, index 2
[ ] Warning: Can't find Pci device with class code 0x60401, index 3
[ ] Find siblings at 0000:00:xx.x
[ ] Sibling found: domain=0000 sec=01 sub=01
[ ] Sibling found: domain=0000 sec=02 sub=02
[ ] Found chipset controller's port at 0000:00:01.0
[ ] mods [1]: set dma mask 47 for dev 0000:01:00.0
[ ] [0000:00:01.0] cap id 0x10 found at offs 0xa0
[ ] [0000:00:01.0] extended cap id 0x1 not found
[ ] [0000:00:1b.0] cap id 0x10 found at offs 0x40
[ ] [0000:00:1b.0] extended cap id 0x1d found at offs 0x0250
[ ] [0000:00:1b.0] extended cap id 0x1 found at offs 0x0100
[ ] Root check: 0000:00:01.0 IsRoot=true
[ ] Connecting ports for Chipset 0000:00:01.0:
[ ] DP0 0000:00:01.0 connects to test device GPU 0 [01:00.0]
[ ] ------Finish bridge detection-----
[ ] Detected potential primary VGA device: GPU 0 [01:00.0]
[ ] Suspended Linux console
[ ] InitializeAllDevices : RM not initialized, skipping GPU nvlink device initialization
[ ] GPU 0 [01:00.0] dev.sub 0.0
[ ] Console: switching consoles 1-1 to colour dummy device 80x25
[ ] DevInst : 0
[ ] PCI Location : 0x00, 0x01, 0x00, 0x00
[ ] GPU DID : 0x2782
[ ] PDI : 0xf2a81c945ce7d7fe
[ ] Raw ECID : 0x011fc20000000004c0c40de1
[ ] Raw ECID (GHS) : 0x17804c0c40c00000008fe0200
[ ] ECID : TSMC-U1C343-08_x-4_y8
[ ] Device Id : AD104
[ ] Revision : a1
[ ] Sub Revision : 15
[ ] NV Base : 0xa2000000
[ ] FB Base : 0x90000000
[ ] IRQ : 11
[ ] MSI-X not supported on GPU 0 [01:00.0], skipping
[ ] Detected supported interrupt types: legacy MSI
[ ] mods [1]: enabled dev 0000:01:00.0
[ ] Disabling interrupt tree 0
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] avg IRQ delay: 0us
[ ] min IRQ delay: 0us
[ ] max IRQ delay: 0us
[ ] Legacy interrupts verified OK
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] MSI verified OK
[ ] Skipping MSI-X verification
[ ] Hooking MSI
[ ] Warning: Can't find Pci device with class code 0x40300, index 2
[ ] Bypassing unsupported vendor: 0x8086Device already uninitialized
[ ] AD104 Azalia: DeviceId: 0x22bc.
[ ] Found 1 controllers (DevId 127)
[ ] SetAspm on GPU: 0x11030042
[ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and r
MODS end : Wed May 29 18:23:11 2024 [1.864 seconds (00:00:01.864 h:m:s)]
这个是LEGACY模式的结果 === MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0 0 0 0
FBIOA1 0 0 0
FBIOB0 0 0 0
FBIOB1 0 0 0
FBIOC0 0 0 0
FBIOC1 0 0 0
Failing Bits:
None
Error Code = 00000000 (OK)
justsoso
2024-5-30 11:05
您好,欢迎加入迅维网,有你更精彩
请遵守论坛管理规则哦!
迅维网管理总则--新手必读
http://www.chinafix.com/thread-5924-1-1.html
帮助中心:
http://www.chinafix.com/misc.php?mod=faq
用户须知:
https://www.chinafix.com/misc.ph ... ction=faq&id=62
操作中如有疑问可咨询迅维客服微信:XW4006631699帮您处理
