可上8-9代BIOS,E3V5系列使用方法:
更新BIOS操作步骤(更新BIOS有风险,请谨慎操作,如果您使用的是独一无二的BIOS,请自行先做BIOS备份工作)
BIOS update procedure (IMPORTANT: Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it.DO NOT forget to back up BIOS setting in case update failure.)
1.准备好一个普通的U盘(不要用DOS盘,不要用winPE的U盘,就是普通U盘格式为FAT32);
Prepare a normal USB flash drive( please format the USB flash drive to FAT32 )
2.把在官网上下载好对应型号的主板BIOS解压出来,将EFI的文件夹拷贝到U盘里面,拆除主板上所有接入的硬盘;
Download the corresponding file to your desktop, copy the EFI document to the root directly of the USB flash drive (should be formated to FAT32),remove all the hard disks on the motherboard.
3.将U盘插到需要刷BIOS的计算机上开机,按“DEL”键进BIOS,把"Startup"的"Flash/BiOS Write Protect"默认设置为"Disabled",按F10保存BIOS退出;
Plug in the USB drive to the PC, press “DEL”to enter BIOS, under "Startup" tap, look for the option "Flash/BiOS Write Protect" and set it to "Disabled", press F10 to save and exit.
4.保存退出后计算机会重启,按F11键进入快捷菜单界面,选择U盘的“UEFI启动选项”会自动进入Shell界面自动刷新BIOS,在刷BIOS的过程中请勿打断刷写过程,否则将不会亮机.
After system restarts, press function key F11 to enter the boot device manu. Select the USB flash drive, then press enter. it will automatically enter Shell and reflash BIOS. Do NOT stop the process at this stage. Otherwise, the display will not turn on.
5.当出现“FPT Operation Successful”。
when appears“FPT Operation Successful”, BIOS flashing is done.
6.刷完BIOS后,拔除U盘,重启计算机按DEL键进入BIOS,按F9加载最佳优化值回车确认加载,F10保存修改并重启计算机回车确认保存并重启。
After the update is finished, plug out the USB flash drive.Once the system restarts, press DEL to enter BIOS set-up. Afterwards, press function key F9 to load BIOS optimized defaults.Then, press function key F10 to save and restart the system, press enter to save and restart the system. BIOS has been successfully updated.
