求助 11pro自动关机 崩溃分析
u1530640
2023-12-9 12:29
求助 11pro自动关机 崩溃分析
换了国产屏 一天关机一回 之前还没有啊
u1530640
2023-12-9 12:35
panicString" : "panic(cpu 1 caller 0xfffffff02bbdfd68): \"i2c3::_checkBusStatus SCL is stuck low; last write status 00010118 int shadow 00010100 xfer 00000000 fifo 00000000 for device roswell\" @AppleS5L8940XI2C.cpp:451\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 20F75\nKernel version: Darwin Kernel Version 22.5.0: Thu Jun 8 17:15:35 PDT 2023; root:xnu-8796.122.5~1\/RELEASE_ARM64_T8030\nFileset Kernelcache UUID: E4C2368CDFCC16452BA12BF658CFDEC7\nKernel UUID: D8535381-32BF-3905-A55A-CE641DB55DF8\nBoot session UUID: 8FF5574E-1E10-4F88-92DC-E7AFAB9F3361\niBoot version:
花晨月夕
2023-12-11 09:20
iPhone重启数据分析表
https://www.chinafix.com/thread-1350670-1-1.html
(出处: 迅维网)
迅维小张
2023-12-11 10:20
您好,欢迎加入迅维网,有你更精彩
请遵守论坛管理规则哦!
迅维网管理总则--新手必读
http://www.chinafix.com/thread-5924-1-1.html
我这边还有一些我们迅维老师整理的维修视频资料,可以发给你免费学习 加我微信领取 13691708525
u1530640
2023-12-11 15:06
花晨月夕 发表于 2023-12-11 09:20
iPhone重启数据分析表
(出处: 迅维网)
看不到:kuqi:
u1530640
2023-12-11 15:08
panicString" : "panic(cpu 1 caller 0xfffffff00ff97d68): \"i2c3::_checkBusStatus SCL is stuck low; last write status 00010110 int shadow 00010100 xfer 00000000 fifo 00000000 for device roswell\" @AppleS5L8940XI2C.cpp:451\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 20F75\nKernel version: Darwin Kernel Version 22.5.0: Thu Jun 8 17:15:35 PDT 2023;
今天的
yesterday....
2023-12-13 22:05
这图片啥样看不见呀
kingabc
2023-12-18 11:52
里面的各个排线先排除一下不行再动板,
1148846694
2024-1-1 22:42
肯定是假屏 又是个刚注册的
回音哥
2024-1-5 21:19
i2c3通路就只有一个触摸座,屏幕导致的
