amit 发表于 2023-7-3 11:04
IN NEW GENERATION BIOS . I FACE SAME PROBLEM . FINALLY I REBUILD ORIGNAL BIOS .SET WORKING
柴油机 发表于 2023-7-3 11:35
How do rebuild BIOS? so have you solved your problem?which one Burner u use
amit 发表于 2023-7-3 11:43
SVOD 3 WITH HEX TOOL AND UEFI TOOL DIFFRENENT LAPTOP DIFFRENT TYPE METHOD I USE
柴油机 发表于 2023-7-3 13:47
maybe serial problem
cqdly2012 发表于 2023-7-4 10:47
具体型号呢?
自带金闪闪 发表于 2023-07-03 10:16
什么板子,AMD还是
