标题: iMac 5K 2019 820-01236 [打印本页] 作者: pau007 时间: 2023-6-27 21:03 标题: iMac 5K 2019 820-01236 The unit is powering on but there is no backlight on the screen. I already change the backlight driver but the still no backlight at all. What should I need to check? Thank you!
