标题: Help me recover SSD EXRAM / KINGSPEC / CeaMere (Realtek RM1135+Hynix 3dv6) [打印本页]
作者: sazdmitrij 时间: 2023-6-14 04:57
On hand there is an EXRAM SSD (aka KINGSPEC P3, CeaMere - https://smarthdd.com/rus/database/P3-128/ZD0R3G50) with a broken firmware (the volume has become 1 MB).
Realtek_SSD_flash_id shows (there is another fully functional SSD):
Fw : ZD0R3G50
Size : 244198 MB [256.1 GB]
FwStr: [REALTEK_RL6643ZD0R3G50_p_tH3V6V5.18]
Bank04: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank06: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank08: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
Bank10: 0xad,0x7e,0x28,0x53,0x2,0xb0,0x0,0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/die
The program itself for the firmware is (SSDMP_2.59.0.0_20220610), automatically detects the memory as Hynix H25BFT8B3B8R-BDJ (H3V6) (3DT), but when trying to flash it stops at step 8 -- Llf Init
That is, the necessary Llf files (bank_imem.ram, etc.) are missing.
I ask for help in finding Llf files to restore this SSD.
手头有一个固件损坏的 EXRAM SSD(又名 KINGSPEC P3,CeaMere - https://smarthdd.com/rus/database/P3-128/ZD0R3G50)(体积已变为 1 MB)。
Realtek_SSD_flash_id 显示(还有另一个功能齐全的 SSD):
固件:ZD0R3G50
大小:244198 MB [256.1 GB]
Bank04:0xad、0x7e、0x28、0x53、0x2、0xb0、0x0、0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/芯片
Bank06:0xad、0x7e、0x28、0x53、0x2、0xb0、0x0、0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/芯片
Bank08:0xad、0x7e、0x28、0x53、0x2、0xb0、0x0、0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/芯片
Bank10:0xad、0x7e、0x28、0x53、0x2、0xb0、0x0、0x0 - Hynix 3dv6-128L TLC 16k 512Gb/CE 512Gb/芯片
固件程序本身是 (SSDMP_2.59.0.0_20220610),自动检测内存为 Hynix H25BFT8B3B8R-BDJ (H3V6) (3DT),但在尝试闪存时它停止在第 8 步 -- Llf Init
也就是说,缺少必要的 Llf 文件(bank_imem.ram 等)。
我请求帮助寻找 Llf 文件来恢复这个 SSD。
作者: u1499643 时间: 2023-6-15 16:01
没看明白想表达啥
作者: aslan28 时间: 2023-7-5 16:02
Hynix 3dv6这个固件不公开,小钱也买不到
作者: u1495818 时间: 2023-7-11 09:55
来自俄国的朋友
作者: sazdmitrij 时间: 2023-8-10 04:34
Пытаюсь сейчас с помощью 1691126435-RM1135_HynixV6_4Lun_ZD1N3G5K_ZD0R3G5K_SSDMP2.58.0.0_20220701 восстановить свой диск, но пока результат тот же, остановка на шаге 8 -- Llf Init, и таймаут.
作者: VXCZFFaU 时间: 2023-8-10 10:24
can you share the tool
作者: VXCZFFaU 时间: 2023-8-11 09:16
Try This the tool,..baru mendapatkan dari tetangga sebelah.semoga bermanfaat
https://www.chinafix.com/thread-1345594-1-1.html
作者: sazdmitrij 时间: 2023-8-13 07:58
Могу, держите -
SSDMP.txt
(37 Bytes, 下载次数: 20)
