烧不烧看天意,有的3.3直通了也没烧,只要不是强上电的,基本死不了作者: lixiangliuyi 时间: 2023-5-7 22:15
Repair it without a second,
斯国一,厉害作者: jingkoo9527 时间: 2023-5-7 22:58
How do you determine if the PCH voltage exceeds the standard due to U1? Instead of considering whether Q26 is damaged? After all, the PCH voltage is derived from Q26 partial voltage, and U1 is only responsible for controlling Q26作者: VXPZ3ExN 时间: 2023-5-14 12:42
