标题: Can you help me to get actual it's parts number ? [打印本页] 作者: karnakaushal71 时间: 2023-2-15 22:13 标题: Can you help me to get actual it's parts number ? Can you help me to get actual it's parts number?
This chip is used at many places. 作者: 张顺峰 时间: 2023-2-16 21:58
主板的版号是多少,我看看我有没有图纸作者: 871197158 时间: 2023-2-16 21:59
可以把芯片干下来,托平,然后翻过来拍照,然后用淘宝识图
也可以根据芯片是哪里的供电,去找料板找到引脚布局一样的,干上去测量不短路就可以上电试试
You can dry the chip, TOP, then turn over and take pictures, then use the Taobao knowledge to power it according to the chip, find the board to find the pin layout, do it, don't short the way, you can try it up.作者: 张顺峰 时间: 2023-2-16 22:16
