求一款能支持三星ssd mas0901m闪存 主控的量产工具
Mosaad
2023-1-9 05:31
Model Name: HS-SSD-C100 120G
Serial Number: 30034335425
Firmware Revision: SN07985
Heads: 16 Cylinders: 16383 Sectors per Track: 63
Current capacity in sectors (CHS mode): 16514064
Total number of user addressable sectors (LBA mode): 234441648
Multiword DMA mode 2 and below are supported
Multiword DMA is selected: mode 2
Ultra DMA mode 6 and below are supported
Ultra DMA is selected: none
SMART feature set supported, enabled
Security Mode feature set supported, not enabled
World Wide Name: 5000000000000006
XHqiao
2023-1-9 13:52
这个真没有
u1488128
2023-3-14 17:55
主控下面的闪存啥型号,要根据主控,闪存型号下载开卡软件
