gingerluo 发表于 2022-12-14 23:58
Namaste.
this is typically done by sending pwrbtn# directly to SB.
This will not bother triggering, ...
karnakaushal71 发表于 2022-12-15 08:59
Namaste pwr btn is one function of sio ..but what about other functions of sio like there's so many gpio pin ?
Namaste pwr btn is one function of sio ..but what about other functions of sio like there's so m ...
Namaste.
This will not bother triggering, but will Not have IO controlled functions such as hw monitoring and fan ctrl.
zhu55747 发表于 2022-12-16 15:15
SB两个字符特别显眼,特别好认
梧州陈春光 发表于 2022-12-17 09:37
这种级别的机器我也在用,稳定耐用
三百六十行 发表于 2022-12-16 09:31
还有南桥北桥 确实挺老 另散热片那个芯片左边不是io吗?
