标题: Toshiba P200-12V [打印本页]
作者: 自由的    时间: 2009-8-12 03:38
Wine was spillt over the notebook and it made damages on several areas of the motherboard. I was able to fix circuit around MAX8734A. Now I am working around ISL6262, to get a power for the CPU.
酒溢出的笔记本电脑,并提出损害赔偿的若干领域的主板。我能修复电路周围MAX8734A 。现在我周围ISL6262工作,以取得权力的CPU 。
酒洒到整个笔记本电脑上了,主板有好几个区域损坏。我能修复 MAX8734A周边电路,现在正在修理ISL6262相关电路,以便得到CPU供电-----张先生译
Markings on the Motherboard are:
主板上的标记是:
ISRAE LA-3711P
Rev:2.0
2007-03-07
Made in China
M/B K000051420 WK 737K
ISRAE L10
20F2
2082296700872
46148151L10
Anyone has a drawing?
任何人都具有借鉴?
有人有这个图纸吗?---张先生译
作者: 自由的    时间: 2009-8-13 02:27
任何人都具有借鉴?
有人有这个图纸吗?---张先生译
作者: 自由的    时间: 2009-8-13 16:35
Solution for the MAX8734A problem:
When notebook (spilled by wine) came to repair shop, ther was only blinking light on power LED, and it was red instead of blue. Circuit around MAX8734A did not provide +5V and + 3.3V. After cleaning cleaning circuit from oxidation, I noticed that signal from LM393, that is supposed to start MAX3784A is not arriving. I first replaced LM393 (PU1), but nothing happend. I analyzed LM393 Inputs and found out that 10k resistor on PIN1 leadding to PIN8 is bad. I added another resistor and MAX8734A started to work.
解MAX8734A问题:
当笔记本电脑(溢出的酒)来修理店,只有闪烁灯的功率LED ,这是红色而不是蓝色。电路周围MAX8734A没有提供+5 V和+电压为3.3V 。经过清洗清洗电路氧化,我注意到,信号由LM393 ,即应开始MAX3784A是没有到达。我第一次更换LM393 ( PU1 ) ,但没有happend 。我分析LM393的投入和发现的10K电阻对PIN1 导致 PIN8是坏的。我还另一个电阻和MAX8734A开始工作。
MAX8734A问题的解决过程:
当被洒了酒损坏的笔记本电脑送到维修店的时候,只有电源电源LED指示灯闪烁,LED为红色而不是蓝色。MAX8734A 周边电路没有给出+5V 和 + 3.3V供电。在清除电路氧化后,我注意到没有了来自LM393 (PU1) 的信号,该信号可能用于启动MAX3784A 。我先替换了LM393,但无任何改变。我分析 LM393 的输入,发现了从1#引脚到8#引脚的10K电阻损坏。我用了个好的换上,MAX8734A开始工作。-----张先生译
作者: 自由的    时间: 2009-8-13 16:37
I still have a problem with circuit around ISL6262.
Can anybody provide circuit diagram?
我仍然有问题,电路周围ISL6262 。
任何人可以提供电路图?
作者: 自由的    时间: 2009-8-14 01:11
More info found on a board:
Hannstar J MV-4
94V-0
作者: 自由的    时间: 2009-8-14 03:39
I try to use drawing of Toshiba A200 which is in some areas similar to P200.  I found out that supply voltage +3.3V is missing on PU11 (ISL6262). I don't have +3VS, only +3VALW. I noticed that I need SUSP coming from ISL6227 PIN21 and I guess that I need SYSON as input of   ISL6227 PIN8.
Anyway, in case of A200 SYSON is generated by KBD controler chip which on P200 does not exsist. So, I guess that SYSON should be generated by ICH-7.
Am I right?
我尝试使用绘图东芝A200是在某些方面类似于规范P200 。我发现3.3V的供电电压是失踪PU11 ( ISL6262 ) 。我没有+3VS ,只有3VALW 。我注意到,我需要挂起来自ISL6227 PIN21和我猜,我需要SYSON作为输入的ISL6227 PIN8 。
无论如何,如果在A200 SYSON所产生的键盘控制器芯片的规范P200不exsist 。所以,我想这应该SYSON所产生的ICH7 。
我对不对?
我是用A200这个区域的图纸代替P200来解决问题,这个区域的图纸两者相似。发现PU11 (ISL6262) 没有了+3.3V 供电。没有了+3VS只有+3VALW在。我注意到需要一个来自 ISL6227  21#引脚的 SUSP ,猜想ISL6227 8#引脚输入需要一个SYSON 信号。
不管怎么说,有可能 A200 的 SYSON 是 KBD 控制器产生的,而这在P200上并不存在。所以我猜测 SYSON  是ICH-7南桥发出的。
请问我说得对吗?
-------张先生译
作者: 自由的    时间: 2009-8-14 15:21
Any comment?
有何评论?
作者: 张先生    时间: 2009-8-14 20:32
我替他翻译了一下,如果论坛的热心朋友看了以后,有好的建议可以用英文也可以用中文写出来。他可以用翻译软件翻译,至少可以起到一定提示作用。
另外他想要LA-3711P的图纸,或者供电部分图纸来分析问题。
ISL6262.pdf
556.7 KB, 下载次数: 44, 下载积分: 下载分 -2 分, 下载 1 次
作者: 张先生    时间: 2009-8-14 21:43
论坛管理员心在飞翔为你提供的图纸在下面链接中
Go to see,and download the schematic LA-3711P please! use left mouse key hit the next line.
http://www.chinafix.com.cn/viewthread.php?tid=132858&extra=
作者: 自由的    时间: 2009-8-15 16:57
Thanks again, 张先生 , for schematic and translation.
再次感谢,张先生,为示意图和翻译。
作者: 自由的    时间: 2009-8-15 17:40
In my previous post I had two bad assumptions.
1. Chip ISL 6267 is not producing SUSP signal on PIN21. PIN 21 is also input.
2. I could not find Keyboard Controller Chip. I thought that ICH7 is also acting to control power.
But, when I saw diagram, there was a big Keyboard controler chip KB910QF.
And I found it. It was very well hidden under PCMCIA socket.
There is a lot of oxidation around KB910QF, and I will try to clean it.
我在以前的帖子我有两个坏的假设。
1. 芯片ISL6267不生产SUSP123信号PIN21 。 PIN21还投入。
2. 我找不到键盘控制器芯片。我认为的ICH7还作为电源管理。
但是,当我看到图,有一个大键盘控制器芯片KB910QF 。
我发现它。芯片是非常隐蔽下PCMCIA插槽。
腿KB910QF是氧化了很多,我将努力清理
在以前的帖子我作了两个不正确的假设:
1. 芯片ISL6267 在21#引脚不生产SUSP信号 。 21#引脚也是作为输入的;
2. 我找不到键盘控制器芯片。我认为ICH7是控制电源的。
但是当我看了图纸以后发现有个叫KB910QF 键盘控制器大芯片,我找到了这个芯片。芯片在PCMCIA插槽下,非常隐蔽。
KB910QF周围锈蚀严重,我先去清理一下。
-------张先生译
