标题: Anyone has Dell 3010 MT bios? [打印本页] 作者: themakers2907 时间: 2021-9-4 15:05 标题: Anyone has Dell 3010 MT bios? Hi chinafix users,
Can anyone send me a bios dump of the dell 3010 MT? Not the DT version but the MT minitower bios of the 3010. I found 2 posts of the bios on this fourm but none of them seems to work and one of them made my computer bootloop while the other had no video. I would not like the DT version as dell only allows 2 of the 4 sata ports to be used, which does not help either.
Thank you
作者: elfxie 时间: 2021-9-4 15:44
I CAN ! just a pc will be fix the same one
