标题: please help fix UUID error, rfid for Lenovo thinkpad E460 NM A511 rev 1.0 [打印本页]
作者: doobour 时间: 2021-6-7 19:13
I have a computer thinkpad E460 NM A551 rev 1.0 i5 6200U .
I replaced the IO IT8586E and saved the IO ec rom. Maybe the copy I saved has errors because when I write the ec rom to the new IO, when I start the machine, it gives an error UUID invalid , RFID invalid .
I've tried looking for other bios, ec roms but nothing changed. In the bios setup the MTM sections, system unit serial number , system board serial number is invalid , the UUID line is FFFFF...
I used the IBM thinkpad Maintenance Diskette 1.9 tool to record the MTM , serial unit , serial board . Everything is OK . Only the UUID doesn't change, even when I go to the assign UUID section of the IBM Maintenance Diskette tool.
now every time i install windows i get error 0189 Invalid RFID configuration information area , and invalid UUID and I have to press ESC to enter windows .
Does anyone know how to recover the UUID ? I don't quite understand because if the HP computer after recording the serial, the UUID will appear again by itself. As for Lenovo, I don't quite understand its UUID .
作者: wuyaping 时间: 2021-6-8 10:29
https://www.chinafix.com/thread-1133087-1-1.html
作者: wuyaping 时间: 2021-6-8 10:33
Download the program in the link and read the manual
Thinkpad Maintenance Disk 使用说明.pdf
(532.81 KB, 下载次数: 32)
