ZXCVWtest
标题: HOW TO EDIT BIN FILE [打印本页]
作者: richman329186    时间: 2021-6-3 16:05
CáCH CHỈNH SỬA BIN FILE TP LINK 841n: KHI GIỮ NúT ĐẶT LẠI TPLINK THƯỜNG XUYêN TẮT DHCP Và THAY ĐỔI TêN WIFI XáC ĐỊNH (SSID = ABCD), MẬT KHẨU WIFI (PW = 12345678)
TÔI THỬ CHỈNH SỬA MÃ NHƯNG KHÔNG THỂ CHẠY ĐƯỢC
作者: cfshen    时间: 2021-6-3 19:42
这人说的什么
作者: xlee5168    时间: 2021-6-3 19:47
5めむねはひふゃょゅなさぅぁこんてちたそせす不错!
作者: richman329186    时间: 2021-6-3 22:03
i want edit bin file  firmware tplink 841n (always turn off dhcp even when resetting the router)
作者: richman329186    时间: 2021-6-3 22:04
