感谢分享,学习了作者: 寻乌电脑专卖店 时间: 2021-5-12 12:01
思路清晰 下次遇到同样故障可以借鉴一下作者: 强唯电脑维修 时间: 2021-5-12 12:56
谢谢楼主的分享 让维修少走弯路作者: 723688296 时间: 2021-7-25 23:14
楼主描写维修过程清晰,有教程风范。作者: asliyucegsm 时间: 2026-8-26 22:34
Thanks, buddy. It would have been even better if you had shared a photo showing which resistor it was. Still, thanks for the effort.
When I press the power button, 3V and 5V appear, but then it shuts down after a few seconds; I'm having this problem. Everything looks normal, and I've tried everything.
CSL50-CSL52 LA-E801P Rev 2.0
Power consumption is 0.12 when the power button is pressed,
then it cuts out.作者: jsxzcy123 时间: 2026-8-27 09:40
