iPhonexsmax不定时自动重启 这种代码是不是只有换屏才能解决
点到晚上
2020-10-1 21:03
好多手机店都说要换个屏幕。 重启代码:build" : "iPhone OS 14.0 (18A373)",
"product" : "iPhone11,6",
"kernel" : "Darwin Kernel Version 20.0.0: Fri Aug 28 23:07:00 PDT 2020; root:xnu-7195.0.46~9\/RELEASE_ARM64_T8020",
"incident" : "98F1BBB4-3760-4756-B4C7-331243174ACE",
"crashReporterKey" : "c2c34505ff090eb6d2d5ff2175f45d957dd4e517",
"date" : "2020-10-01 18:57:39.21 +0800",
"panicString" : "panic(cpu 0 caller 0xfffffff00fc1f3d8): \"i2c3::_checkBusStatus Bus is still in a bad state; last write status 00010110 int shadow 00010100 xfer 00000000 fifo 00000000 for device display-pmu\"\nDebugger message: panic\nMemory ID: 0xff\nOS release type: Not set yet\nOS version: Not set
大顺数码
2020-10-20 12:33
屏幕吧吧,屏幕上IC坏了也会这样。
letmebe1234
2020-11-15 12:10
i2c3 .....
成成1221
2020-11-17 04:00
给你个好用的公众号,超级好用
