panicString" : "panic(cpu 2 caller 0xfffffff013698040): \"i2c3::_checkBusStatus Bus is still in a bad state; last read status 00010110 int shadow 00010100 xfer 00000000 fifo 00000000 for device display-pmu\"@\/Library\/Caches\/com.apple.xbs\/Sources\/AppleS5L8940X\/AppleS5L8940X-169.0.1\/AppleS5L8940XI2C.cpp:351\nDebugger message: panic\nMemory ID: 0xff\nOS version: 17H35\nKernel version: Darwin Kernel Version 19.6.0: Sat Jul 11 00:58:55 PDT 2020; root:xnu-6153.142.1~8\/RELEASE_ARM64_T8020\nKernel UUID: C90D714D-EB36-3B76-9EF0-6C569DE311CA\niBoot version:
panicString" : "panic(cpu 2 caller 0xfffffff013698040): \"i2c3::_checkBusStatus Bus is still in a bad state; last read status 00010110 int shadow 00010100 xfer 00000000 fifo 00000000 for device display-pmu\"@\/Library\/Caches\/com.apple.xbs\/Sources\/AppleS5L8940X\/AppleS5L8940X-169.0.1\/AppleS5L8940XI2C.cpp:351\nDebugger message: panic\nMemory ID: 0xff\nOS version: 17H35\nKernel version: Darwin Kernel Version 19.6.0: Sat Jul 11 00:58:55 PDT 2020; root:xnu-6153.142.1~8\/RELEASE_ARM64_T8020\nKernel UUID: C90D714D-EB36-3B76-9EF0-6C569DE311CA\niBoot version: 作者: jycjycjycjycjyc 时间: 2020-9-14 21:45
估计哪个电感虚汗了 作者: 会员1108885 时间: 2020-9-15 00:45
摄像头没扣好
