标题: MATS安装出错最后一步直接报错 [打印本页] 作者: 天王功能工作室 时间: 2020-9-7 22:47 标题: MATS安装出错最后一步直接报错 cs@ubuntu:~/MATS-367.38.1$ sudo ./install_module.sh -i
make:进入目录'/home/cs/MATS-367.38.1/driver'
make -C /lib/modules/4.4.0-31-generic/build M=/home/cs/MATS-367.38.1/driver clean
make[1]: 正在进入目录 `/usr/src/linux-headers-4.4.0-31-generic'
make[1]:正在离开目录 `/usr/src/linux-headers-4.4.0-31-generic'
make:离开目录“/home/cs/MATS-367.38.1/driver”
make -C /lib/modules/4.4.0-31-generic/build M=/home/cs/MATS-367.38.1/driver modules
CC [M] /home/cs/MATS-367.38.1/driver/mods_krnl.o
CC [M] /home/cs/MATS-367.38.1/driver/mods_mem.o
CC [M] /home/cs/MATS-367.38.1/driver/mods_irq.o
CC [M] /home/cs/MATS-367.38.1/driver/mods_pci.o
CC [M] /home/cs/MATS-367.38.1/driver/mods_acpi.o
CC [M] /home/cs/MATS-367.38.1/driver/mods_debugfs.o
LD [M] /home/cs/MATS-367.38.1/driver/mods.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/cs/MATS-367.38.1/driver/mods.mod.o
LD [M] /home/cs/MATS-367.38.1/driver/mods.ko
make -C /lib/modules/4.4.0-31-generic/build M=/home/cs/MATS-367.38.1/driver modules_install
INSTALL /home/cs/MATS-367.38.1/driver/mods.ko
At main.c:222:
- SSL error:02001002:system library:fopen:No such file or directory: bss_file.c:169
- SSL error:2006D080:BIO routines:BIO_new_file:no such file: bss_file.c:172
sign-file: certs/signing_key.pem: No such file or directory
DEPMOD 4.4.0-31-generic
depmod: WARNING: -e needs -E or -F
To load the mods module on boot, add it to /etc/modules
cs@ubuntu:~/MATS-367.38.1$ ./check_config.sh
Checking OS... Linux - OK
Checking kernel version... 4.4.0 - WARNING - unrecognized kernel version
Checking architecture... x86_64 - OK
Checking libc version... 2.19 - OK
Checking MODS kernel module... 3.66 - OK
Checking conflicting kernel modules... none - OK
Checking console blank inverval... 600 - -e WARNING - please disable console blanking to avoid stability issues, run as root: # echo -ne '\033[9;0]\033[14;0]' > /dev/console
Looking for NVIDIA GPUs... ERROR - no NVIDIA GPUs found
cs@ubuntu:~/MATS-367.38.1$ ./install_module.sh -r
-e The install_module.sh script must be run with root privileges
以上是问题出处最后一步安装出现严重错误
