求大神帮忙修改一个BIOS屏蔽显存
燃烧de心
2020-5-28 18:53
求大神帮忙修改一个BIOS屏蔽显存
求助论坛大神
帮忙屏蔽一块Q4000显卡显存,该显存更换2次后无果,拆下显存测量有数据线开路估计是过孔不良。希望有大神帮忙修改验证。
链接:
https://pan.baidu.com/s/1NGCSe075ASjjZB8VkN_Hgg
提取码:efdk
mats version 265.33. Testing GF100 with 2048 MB of memory.
Errors found. Use .Status() or .PrintErrors() for more info.
This message will only appear once.
LANE EB0 READ ERR EB0 WRT ERR UNKNOWN ERR
FBIOB[31: 0] 0 0 0
FBIOB[63:32] 0 0 0
FBIOC[31: 0] 0 0 0
FBIOC[63:32] 0 337760 0
FBIOD[31: 0] 0 0 0
FBIOD[63:32] 0 0 0
FBIOE[31: 0] 0 0 0
FBIOE[63:32] 0 0 0
External Bank 0 Failing bits:
C37
Read Error Count: 0
Write Error Count: 337760
Unknown Error Count: 0
BIT FRONT WRITE FRONT READ UNKNOWN
C37 42220 0 0
C37 42220 0 0
C37 42220 0 0
C37 42220 0 0
C37 42220 0 0
C37 42220 0 0
C37 42220 0 0
C37 42220 0 0
ADDRESS EXPECTED ACTUAL REREAD1 REREAD2 FAILBITS TPLEIBC ROW COL
dskfl;dskl;
2020-5-29 09:41
你的找牛人给你写
ggw25
2020-5-29 11:18
能干这事的确实是牛人了
virginlulu
2020-5-31 11:08
屏蔽单独颗粒,厉害了了我的哥
燃烧de心
2020-5-31 11:40
virginlulu 发表于 2020-5-31 11:08
屏蔽单独颗粒,厉害了了我的哥
屏蔽通道,不是单颗
