8p无限重启,请大佬分析下代码和故障原因
yingmu
2020-5-1 18:10
苹果8p无限白苹果,有时候又能开机正常使用。看了一下重启代码,i2c1。在论坛上找了很久也没找到这个故障代码一样。请各位大佬给分析下原因,应该怎么维修,维修费用大约是多少?为啥图片一直上传不清楚,我把错误代码复制一下发上来吧。{"bug_type":"210","timestamp":"2020-05-01 15:37:18.00 +0800","os_version":"iPhone OS 13.4.1 (17E262)","incident_id":"A1764926-C3E3-4CD1-9C18-3AC451515CB8"}
"build" : "iPhone OS 13.4.1 (17E262)",
"product" : "iPhone10,2",
"kernel" : "Darwin Kernel Version 19.4.0: Mon Feb 24 22:04:29 PST 2020; root:xnu-6153.102.3~1\/RELEASE_ARM64_T8015",
"incident" : "A1764926-C3E3-4CD1-9C18-3AC451515CB8",
"crashReporterKey" : "8530b18ba36922f3bf09ee3bb128e6f04074186b",
"date" : "2020-05-01 15:37:11.93 +0800",
"panicString" : "panic(cpu 4 caller 0xfffffff013592d44): \"i2c1::_checkBusStatus SCL is stuck low; last read status 00010108 int shadow 00010100 xfer 00000000 fifo 00000000 for device mic-temp-sens2\"@\/AppleInternal\/BuildRoot\/Library\/Caches\/com.apple.xbs\/Sources\/AppleS5L8940X\/AppleS5L8940X-169.0.1\/AppleS5L8940XI2C.cpp:351\nDebugger message: panic\nMemory ID: 0x6\nOS version: 17E262\nKernel version: Darwin Kernel Version 19.4.0: Mon Feb 24 22:04:29 PST 2020; root:xnu-6153.102.3~1\/RELEASE_ARM64_T8015\nKernel UUID: AE262AF6-F6C8-351C-9C4A-ECEC94CB1F50\niBoot version: iBoot-5540.102.4\nsecure boot?: YES\nPaniclog version: 13\nKernel slide: 0x000000000b01c000\nKernel text base:
yingmu
2020-5-1 18:12
为啥上传图片这么不清楚
yingmu
2020-5-1 18:18
故障代码"panicString" : "panic(cpu 4 caller 0xfffffff013592d44): \"i2c1::_checkBusStatus SCL is stuck low; last read status 00010108 int shadow 00010100 xfer 00000000 fifo 00000000 for device mic-temp-sens2\"@
嘿,羞手机!
2020-5-2 22:42
麦克风2 尾排
