标题: 笔记本点位图用Boardview打开的办法 Solution for Boardview opening error [打印本页]
作者: Chinafix 时间: 2020-3-16 11:03
鑫智造中,如果打不开TVW,GR等格式文件,是Boardviewer设置问题,看图:
In Xinzhizhao, if the format files such as TVW and GR cannot be opened, it is a problem with Boardviewer settings. As shown in the figure:
笔记本点位图中Boardviewer 打开报错的解决办法:
The solution to the Boardviewer opening error in the laptop bitmap:
1、↓↓↓如果打开就报错提示缺少.netframwork,请自行百度搜索安装4.0以上.netframeworkIf an error is reported when the. netframework is opened, please search and install. netframework above 4.0 by yourself
https://www.baidu.com/s?ie=utf8&oe=utf8&wd=%2Enetframework&tn=98010089_dg&ch=5
(建议使用 4.0.30319版本:https://www.microsoft.com/en-us/download/details.aspx?id=17718)。
2、↓↓↓如果BoardViewer软件能打开但点位图打开报错,可以点击选项--图形,把GDI选中,拉到最右边。If the BoardViewer software can be opened, but an error is reported when the bitmap is opened, you can click the option - Graph to select GDI and pull it to the far right.
也可以下载http://boardviewer.net中 “boardviewer.zip” 覆盖到安装目录
3、↓↓↓如果打开FZ格式点位图完全没反应,或提示选择用对应的程序打开,或者打开后是英文的boardviewer界面,可以这样设置。If there is no response when opening the FZ format bitmap, or you are prompted to choose to open it with the corresponding program, you can set it as follows
4、↓↓↓如果出现这个错误提示。If this error prompt appears
请先运行鑫智造安装包里的文件“提示缺少文件就安装这个:微软常用运行库合集_2019.07.20_X64.exe” Please run the file in the Xinzhizao installation package first. If there is a missing file prompt, install this: Microsoft Common Runtime Library Collection _2019.07.20_X64. exe
如果不行,可到C:\Program Files (x86)\XinZhiZao\bin\BoardViewer,以管理员权限运行BoardViewer.exe,按图设置。Please go to C: Program Files (x86) XinZhiZao bin BoardViewer, Run BoardViewer.exe with administrator privileges, and set as shown.
如果还是不行,请自行搜索C++组件并安装:Microsoft Visual C++ 2015 Redistributable (x64),If it still doesn't work, please search for C++components and install them yourself: Microsoft Visual C++2015 Redistributable (x64)
5、如果提示数据载入错误,说明不兼容这个点位图文件,要用厂家专用点位图软件才可以打开。If a data loading error is prompted, it indicates that this is incompatible. It can only be opened with a special bitmap software
6、↓↓↓如果出现这个错误提示 If this error prompt appears:
请下载附件
BoardViewer.zip
(468.1 KB, 下载次数: 1121)
,解压后,找到C:\Program Files (x86)\XinZhiZao\bin\BoardViewer文件夹里面的BoardViewer.exe,替换BoardViewer.exe Please download the attachment, unzip it, find BoardViewer.exe in C: Program Files (x86) XinZhiZao bin BoardViewer folder, and replace BoardViewer.exe
如果仍然解决不了,可以把C:\Program Files (x86)\XinZhiZao 文件夹改个名If the problem still cannot be solved, change the name of the C: Program Files (x86) XinZhiZao folder
如果还是有问题可以安装todesk或向日葵,联系鑫智造客服微信:18823306625远程协助解决
If you still have any questions, you can contact us:whatsapp +8618823306625
作者: ibmt430p 时间: 2020-3-18 13:36
问哈boardviewer 启动报0xc000007b 怎么解决
作者: 27788828 时间: 2020-4-2 17:25
我的也是经常报错
作者: ibmt430p 时间: 2020-4-15 10:38
4.0以上.netframework已装
百度无果 不想装系统
作者: xunwei179343098 时间: 2020-6-3 20:28
解决了吗,我也是一样的问题
作者: ibmt430p 时间: 2020-6-4 11:54
没解决 好像是说dll文件有问题
不整了 等需要时 换个系统装
作者: wangjieaaa 时间: 2020-7-27 09:58
.netframework可以在系统高级设置里勾选会自动安装,不用百度,百度还容易下一大堆病毒,例如改主页什么的
作者: 月饼 时间: 2020-9-16 10:24
已经装好的系统,怎么勾选?
作者: 海上权威 时间: 2021-7-12 13:55
BoardViewer打开提示应用程序正常初始化(0xc0000135)失败,如何解决
作者: 月饼 时间: 2021-12-28 17:01
可能不支持xp吧。这个是第三方软件,鑫智造只是调用,具体打不开的原因未知。
作者: 月饼 时间: 2023-2-27 10:32
BoardViewer各版本下载
BoardViewer 1.1.4.0.zip
1.59 MB, 下载次数: 41
BoardViewer 1.2.0.0.zip
1.11 MB, 下载次数: 18
BoardViewer 2.0.1.8 理论界汉化.zip
2.31 MB, 下载次数: 43
BoardViewer 2.0.1.8 玲珑心汉化.zip
2.38 MB, 下载次数: 46
BoardViewer 2.0.1.9 beta 玲珑心汉化.zip
1.4 MB, 下载次数: 112
BoardViewer 2.0.1.9 beta.zip
1.4 MB, 下载次数: 57
作者: u1488737 时间: 2023-3-16 01:16
BoardViewer各版本下载
作者: sjzy 时间: 2025-7-7 12:17
打开报错 点继续 再打开一次就好了 我一直这么用的
Powered by Discuz! X3.4 |
