标题: ASUS A68HM-K REV1.00有时会自动开启电源,有时不会触发并重设 [打印本页]
作者: dbg167    时间: 2020-1-3 18:17
ASUS A68HM-K REV1.00 sometimes automatically power on, sometimes it does not trigger and reset
Power switch voltage up and down
Sometimes 2.97V, 1.45V, 1.79V,
with
Corrected 1.45V at some time
After finding it I checked 1.45V
It comes from 3VSB.
3VSB is converted from 5VSB
3VSB comes from PU601.
I check if PU601 has a device circuit
PU601 PIN 2 is connected to PR604, it is 1.27K, but I removed and checked it.
Its value is becoming 8.5K
I changed 1.27K to 1.50K.
After non-automatic startup, the trigger is successful, and the code is run and displayed perfectly.
作者: 头孢氨苄    时间: 2020-1-4 21:52
外国人吗,看着很吃力,应该是换电阻修好了吧
