标题: 盈通9500 128m ddr帮忙看下是不是显存的问题,是哪个显存的问题? [打印本页] 作者: 刘小川 时间: 2009-7-14 18:15 标题: 盈通9500 128m ddr帮忙看下是不是显存的问题,是哪个显存的问题? R3MEMID version 1.07, (c) Copyright ATI Technologies Inc, 2003
Log file generation enabled to .\R3MEMID.LOG ...
Reference data file (RDF) loading disabled ...
TEST RESULT SUMMARY:
Rv350 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID 0VB001
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
failing bit : MDB0 24 25 26 27 28 29 30 31
[2 ] Data line toggle (GUI) : FAIL
Error ID 0VB023
[3 ] RW page (GUI) : FAIL
Error ID 0VB025
[4 ] RW channel (GUI) : FAIL
Error ID 0VB028
[5 ] Data mask : FAIL
Error ID 0VB006
[6 ] Macro + Micro8x2 tiling read : FAIL
Error ID 0VC006
[7 ] Byte swap macro+micro8x2 read : FAIL
Error ID 0VC018
[8 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID 0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.8 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.8 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.8 not found
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
error : R055A.8 not found
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.8 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.8 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.8 not found
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
error : R065A.8 not found
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.8 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.8 not found
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.8 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
error : R075A.8 not found
[9 ] Line slopes/dir/P/solid : FAIL
Error ID 0TR010
error : R051A.9 not found
error : R052A.9 not found
error : R053A.9 not found
error : R055A.9 not found
error : R061A.9 not found
error : R062A.9 not found
error : R063A.9 not found
error : R065A.9 not found
error : R071A.9 not found
error : R072A.9 not found
error : R073A.9 not found
error : R075A.9 not found
Failure detected.
