查看: 1288|回复: 2
[显卡维修]
ATI9200AGP 128MB显卡测试结果请大家看一下是哪里的问题?
发表于 2009-7-14 17:14:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
R6XMEMID version 1.02, (c) Copyright ATI Technologies Inc, 2002
Log file generation enabled to .\R6XMEMID.LOG ...
Loading Checksum and Gui CRC data from RDF file 'C:\R6MEMID\R6XMEMID.M9' ...
Checksum Data Done.
No GUI CRC Data loaded from RDF.
TEST RESULT SUMMARY:
Rage6 Ya detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Memory Interface Data Test                          : PASS
[2  ] Memory Interface Address Test                       : PASS
[3  ] Fill ALL memory then read                           : PASS
[4  ] Read-Modify-Write                                   : PASS
[5  ] Micro+Macro tiling read                             : PASS
[6  ] 32-bit Z tiling write                               : PASS
[7  ] Byte swap z32 read                                  : PASS
[8  ] Micro+Marco alignment write                         : PASS
[9  ] 16-bit Z alignment read                             : PASS
[10 ] Basic solid rectangles                              : PASS
[11 ] PM4 T3 Indirect buf                                 : SKIPPED
[12 ] Line slopes/dir/P/solid                             : PASS
[13 ] HOST_DATA/<f,b>/M2L                                 : PASS
[14 ] HOST_DATA/color                                     : PASS
No failures detected.
是哪里的问题?
发表于 2009-7-14 20:03:00 | 只看该作者 �
进系统花屏?还是死机?
发表于 2009-7-16 13:37:27 | 只看该作者 �
只是给你参考 应该是花屏 没看到错误 建议水洗 烘干 再试
