标题: Dell 3420 could not start [打印本页]
作者: thanhnamvl86    时间: 2019-10-22 20:48
Dell 3420 no bootable, checks sơ bộ nắp # = 3.3v, PSL_IN2 # = 3.3v, PU4002 testing added 3 chan G, D, S = 19V (thất bại), Tiếp tục checks PQ4002 with the chan 2 ( PWR_CHG_ACOK) = 0V (Fail), Check PQ4006 for found chan G (AC_IN #) Trying to áp suất cao make Thái nhi dẫn from D to S. AC_IN # = ACOK # (chan 5 IC BQ24727). Tiến hành kéo AC_IN # lên khối lượng, replacement PC4001 bằng 1k máy started động. máy started động .Đay is exercises, trò chơi, tham gia, tập trung and sức mạnh của trò chơi, trò chơi and trò chơi.
作者: H55    时间: 2019-10-22 20:57
看不懂是什么文字啊,, 泰国 还是缅甸的 老铁? 你说的 是 开机 提示 65W 报错???????
作者: thanhnamvl86    时间: 2019-10-22 21:04
I use English. Currently I use a power supply, not an adapter, so it doesn't recognize the charger. Newspaper must use 65W charger
作者: yericl    时间: 2019-10-23 07:35
DELL Use the One wire protocol to communicate with the charger, after reading the data from charger mid-pin and verifying the CRC, it could be examined to find the field that specifies voltage and current.
Charger with damage or no mid-pin may still power on the laptop, but display a warning message and not charging the battery.
You can get a female 5.5 x 2.5 to male dell 7.5 x 5.0 charger adapter DC jack from an online store to send fake data to the laptop pretending DELL charger.
作者: thanhnamvl86    时间: 2019-10-23 09:32
yericl 发表于 2019-10-23 07:35
DELL Use the One wire protocol to communicate with the charger, after reading the data from charger  ...
Thanks for you, I live in VietNam , When the repair is mainly using a universal charger for the line-up machine, you can give me the correct image for me to buy online.
作者: yy2011..    时间: 2019-10-23 13:11
看不懂
作者: lpz2012    时间: 2019-10-23 14:52
哪个大哥来翻译下。?!
作者: 天地融    时间: 2019-10-23 15:05
越南人英语这么好。
作者: 开始21012    时间: 2019-10-23 15:31
他的意思是 维修过程
作者: 5226564    时间: 2019-10-23 20:32
thanhnamvl86 发表于 2019-10-23 09:32
Thanks for you, I live in VietNam , When the repair is mainly using a universal charger for the li ...
https://detail.tmall.com/item.ht ... 27b&abbucket=11
This should work, and Dell has two kinds of power heads, big mouth with needle, small mouth with needle. The power head has a built-in chip, which can simulate the original adapter and has the function of charging. You should be able to buy it on Taobao.
作者: yericl    时间: 2019-10-24 02:03
lpz2012 发表于 2019-10-23 14:52
哪个大哥来翻译下。?!
连蒙带猜,估计意思像是他直接用可调电源连入充电口的正负极来开机,但开机后有他图上的错误信息,问有什么解决方案。
作者: 极致科技    时间: 2019-10-24 07:12
说的是ACOK检测为0V,等等
作者: 培众    时间: 2019-10-25 11:01
客户没有电源吗,直接换个电源就好了呀,如果自己拿来测试可以用转接头
作者: 1274641737    时间: 2019-10-25 11:08
看来这位是外国友人,我一句没看懂,图纸倒看一点
作者: 1KB电脑维修    时间: 2019-10-25 11:18
下个翻译软件整成中文的在发,看不懂
作者: thanhnamvl86    时间: 2019-10-25 12:25
1KB电脑维修 发表于 2019-10-25 11:18
下个翻译软件整成中文的在发,看不懂
Sorry, i don't know speak china, i use google.
作者: chxj    时间: 2019-10-25 12:32
都没看懂什么意思,看图应该是充电器问题吧,有的BIOS里面可以改的
作者: 海成科技1888    时间: 2019-10-25 12:33
这个贴。考研英语水平
作者: thanhnamvl86    时间: 2019-10-25 12:42
PQ4002 Fail. PQ4002 error needs replacement to use charger and battery.
