标题: GANDCRAB V2.1 [打印本页]
作者: 沟通100(提兴电    时间: 2019-10-16 22:53
标题: GANDCRAB V2.1
---= GANDCRAB V2.1 =---
Attention!
All your files documents, photos, databases and other important files are encrypted and have the extension: .CRAB
The only method of recovering files is to purchase a private key. It is on our server and only we can recover your files.
The server with your key is in a closed network TOR. You can get there by the following ways:
0. Download Tor browser - https://www.torproject.org/
1. Install Tor browser
2. Open Tor Browser
3. Open link in TOR browser: http://gandcrab2pie73et.onion/19100d7e20bf4465
4. Follow the instructions on this page
If Tor/Tor browser is locked in your country or you can not install it, open one of the following links in your regular browser:
0. https://gandcrab2pie73et.onion.rip/19100d7e20bf4465
1. https://gandcrab2pie73et.onion.plus/19100d7e20bf4465
2. https://gandcrab2pie73et.onion.to/19100d7e20bf4465
ATTENTION! Use regular browser only to contact us. Buy decryptor only through TOR browser link or Jabber Bot!
On our page you will see instructions on payment and get the opportunity to decrypt 1 file for free.
The alternative way to contact us is to use Jabber messanger. Read how to:
0. Download Psi-Plus Jabber Client: https://psi-im.org/download/
1. Register new account: http://sj.ms/register.php
    0) Enter "username": 19100d7e20bf4465
    1) Enter "password": your password
2. Add new account in Psi
3. Add and write Jabber ID: ransomware@sj.ms any message
4. Follow instruction bot
It is a bot! It's fully automated artificial system without human control!
To contact us use TOR links. We can provide you all required proofs of decryption availibility anytime. We are open to conversations.
You can read instructions how to install and use jabber here http://www.sfu.ca/jabber/Psi_Jabber_PC.pdf
DANGEROUS!
Do not try to modify files or use your own private key - this will result in the loss of your data forever!
有会的吗
作者: 沟通100(提兴电    时间: 2019-10-16 22:54
有高手,请联系一我 407009401  QQ
