标题: Error (0x000000a5) [打印本页] 作者: karnakaushal71 时间: 2019-8-14 15:51 标题: Error (0x000000a5) Error (0x000000a5)
Solution:-
1:- I tried to change hdd and ram but problem was same
2:- next I tried to update bios with clean me region but problem same
3:- I tried another processor but always same problem
Then I study on error and get solution the solution was
Insert bootable pendrive/cd and go into repair option and choose command prompt
On that choose
First C:\bootrec/fixMbr
2nd C:\bootrec/FixBoot
3rd C:\bootrec/RebuildBcd
And then C:\Exit from their and restart pc problem was solve..
