Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Mon 08/05/2019 15:59:47] - SF_Genesis has been invoked with the following parameters:
[Mon 08/05/2019 15:59:47] - Instructing the operating system to purge any existing cached data for device: '3:0:0:0'
[Mon 08/05/2019 15:59:52] - Issuing a discovery command for device: '3:0:0:0'
[Mon 08/05/2019 15:59:57] - Discovery command completed...
[Mon 08/05/2019 15:59:57] - Waiting 5 seconds for the system to settle...
[Mon 08/05/2019 16:00:02] - Device designation string '3:0:0:0' is mapped to node '/dev/sg1'
[Mon 08/05/2019 16:00:02] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg1
MFP Package Filename = /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
Configuration File = /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig
Serial No. = 42
World Wide Name = 42
[Mon 08/05/2019 16:00:03] - Successfully received the IDENTIFY data from the drive...
[Mon 08/05/2019 16:00:03] - Validating Manufacturing Firmware Package: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Mon 08/05/2019 16:00:03] - Successfully opened the package: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/FW_PPRO_5_8_2_Release.906190.release.123456.mfp
[Mon 08/05/2019 16:00:03] - file /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig Loaded successfully
[Mon 08/05/2019 16:00:03] - Warning: Unable to query diagnostics information to perform power management settings check
[Mon 08/05/2019 16:00:03] - B01 Power Management configuration request detected
[Mon 08/05/2019 16:00:03] - Successfully extracted *.DriveConfig file: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig
[Mon 08/05/2019 16:00:03] - Extracted Config_ID: 1 (28026) in DriveConfig file: /root/mpt/FW_PPRO_5_8_2_Release.906190.release--123456/28026.123456.driveconfig
[Mon 08/05/2019 16:00:03] - Extracted SerialOutputControl: 0
[Mon 08/05/2019 16:00:03] - Searching for flashware image for configuration 28026
[Mon 08/05/2019 16:00:03] - Manifest found for configuration 28026
[Mon 08/05/2019 16:00:03] - Flashware image extracted: 28026_fw_cl_ccmlc_Intel_64Gb_JS29F32B08JCME2_1Q_4C_1D_S_PP_R01298_s512.vic
[Mon 08/05/2019 16:00:03] - Searching for manufacturing image for configuration 28026
[Mon 08/05/2019 16:00:03] - Manufacturing image extracted: 28026_mf_ccmlc_Intel_64Gb_JS29F32B08JCME2_1Q_4C_1D_S_PP_R01298_s512.vic
[Mon 08/05/2019 16:00:03] - Proceeding in ROM mode, download feature 3...
[Mon 08/05/2019 16:00:03] - Successfully downloaded MFB to the drive...
[Mon 08/05/2019 16:00:03] - Waiting (5 sec) for the drive to settle...
[Mon 08/05/2019 16:00:08] - Successfully received the IDENTIFY data from the drive...
[Mon 08/05/2019 16:00:08] - Firmware revision reported to be: '582ABBM0'. This indicates MFB download was successful.
[Mon 08/05/2019 16:00:08] - Successfully enabled SMART capabilities...
[Mon 08/05/2019 16:00:11] - Successfully issued a diagnostic unlock...
[Mon 08/05/2019 16:00:12] - Performing the flash test of block 0 (0x0000)...
[Mon 08/05/2019 16:00:15] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 1
Chip Enabled Count: 4
Die Count: 1
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
Total Number of test results: 16
Number of failures: 0
Number of Passed with warnings: 16
No. Passed without warnings: 0
[Mon 08/05/2019 16:00:50] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))
[Mon 08/05/2019 16:00:50] - End of Genesis manufacturing log.
[Mon 08/05/2019 16:00:50] - Exiting...
