CISCO | H3C | HUAWEI | ÃèÊö |
no | undo | undo | È¡Ïû¡¢¹Ø±Õµ±Ç°ÉèÖà |
show | display | display | ÏÔʾ²é¿´ |
exit | quit | quit | ÍË»ØÉϼ¶ |
hostname | sysname | sysname | ÉèÖÃÖ÷»úÃû |
en, config terminal | system-view | system-view | ½øÈëÈ«¾Öģʽ |
delete | delete | delete | ɾ³ýÎļþ |
reload | reboot | reboot | ÖØÆô |
write | save | save | ±£´æµ±Ç°ÅäÖà |
username | local-user | local-user | ´´½¨Óû§ |
shutdown | shutdown | shutdown | ½ûÖ¹¡¢¹Ø±Õ ¶Ë¿Ú |
show version | display version | display version | ÏÔʾµ±Ç°ÏµÍ³°æ±¾ |
show startup-config | display saved-configuration | display saved-configuration | ²é¿´Òѱ£´æ¹ýµÄÅäÖà |
show running-config | display current-configuration | display current-configuration | ÏÔʾµ±Ç°ÅäÖà |
no debug all | ctrl+d | ctrl+d | È¡ÏûËùÓÐdebugÃüÁî |
erase startup-config | reset saved-configuration | reset saved-configuration | ɾ³ýÅäÖà |
end | return | return | Í˵½Óû§ÊÓͼ |
exit | logout | logout | µÇ³ö |
logging | info-center | info-center | Ö¸¶¨ÐÅÏ¢ÖÐÐÄÅäÖÃÐÅÏ¢ |
line | user-interface | user-interface | ½øÈëÏß·ÅäÖã¨Óû§½Ó¿Ú£©Ä£Ê½ |
start-config | saved-configuration | saved-configuration | Æô¶¯ÅäÖà |
running-config | current-configuration | current-configuration | µ±Ç°ÅäÖà |
host | ip host | ip host | hostÃû×ÖºÍipµØÖ·¶ÔÓ¦ |
½»»»²¿·Ö | |||
enable password | set authentication password simple | set authentication password simple | ÅäÖÃÃ÷ÎÄÃÜÂë |
interface type/number | interface type/number | interface type/number | ½øÈë½Ó¿Ú |
interface vlan 1 | interface vlan 1 | interface vlan 1 | ½øÈëvlanÅäÖÃvlan¹ÜÀíµØÖ· |
interface rang | interface ethID to ID | interface ethID to ID | ¶¨Òé¶à¸ö¶Ë¿ÚµÄ×é |
enabl esecret | super password | super password | ÉèÖÃÌØÈ¨¿ÚÁî |
duplex (half|full|auto) | duplex (half|full|auto) | duplex (half|full|auto) | ÅäÖýӿÚ״̬ |
speed (10/100/1000) | speed (10/100/1000) | speed (10/100/1000) | ÅäÖö˿ÚËÙÂÊ |
switchport mode trunk | port link-type trunk | port link-type trunk | ÅäÖÃtrunk |
vlan ID /no vlan ID | vlan batch ID /undo vlan batch ID | vlan batch ID /undo vlan batch ID | Ìí¼Ó¡¢É¾³ývlan |
switchport access vlan | port default vlan ID | port acces vlan ID | ½«¶Ë¿Ú½ÓÈëvlan |
show interface | display interface | display interface | ²é¿´½Ó¿Ú |
show vlan ID | display vlan ID | display vlan ID | ²é¿´vlan |
encapsulation | link-protocol | link-protocol | ·â×°ÐÒé |
channel-group 1 mode on | port link-aggregation group 1 | port link-aggregation group 1 | Á´Â·¾ÛºÏ |
ip routing | ĬÈÏ¿ªÆô | ĬÈÏ¿ªÆô | ¿ªÆôÈý²ã½»»»µÄ·Óɹ¦ÄÜ |
no switchport | ²»Ö§³Ö | ²»Ö§³Ö | ¿ªÆô½Ó¿ÚÈý²ã¹¦ÄÜ |
vtp domain | GVRP | GVRP | ¶Ô¿çÒÔÌ«Íø½»»»»úµÄVLAN½øÐж¯Ì¬×¢²áºÍɾ³ý |
spanning-tree vlan ID root primary | stp instance id root primary | stp instance id root primary | stpÅäÖøùÍøÇÅ |
spanning-tree vlan ID priority | stp primary vlaue | stp primary vlaue | ÅäÖÃÍøÇÅÓÅÏȼ¶ |
show spanning-tree | dis stp brief | dis stp brief | ²é¿´STPÅäÖà |
·Óɲ¿·Ö | |||
ip route 0.0.0.0 0.0.0.0 | ip route-static 0.0.0.0 0.0.0.0 | ip route-static 0.0.0.0 0.0.0.0 | ÅäÖÃĬÈÏ·ÓÉ |
ip route Ä¿±êÍø¶Î+ÑÚÂë ÏÂÒ»Ìø | ip route-static Ä¿±êÍø¶Î+ÑÚÂë ÏÂÒ»Ìø | ip route-static Ä¿±êÍø¶Î+ÑÚÂë ÏÂÒ»Ìø | ÅäÖþ²Ì¬Â·ÓÉ |
show ip route | display ip routing-table | display ip routing-table | ²é¿´Â·Óɱí |
router rip /network Íø¶Î | rip /network Íø¶Î | rip /network Íø¶Î | ÆôÓÃrip¡¢²¢Ðû¸æÍø¶Î |
router ospf | ospf | ospf | ÆôÓÃospf |
network ip ·´Âë area <area-id> | area <area-id> | area <area-id> | ÅäÖÃOSPFÇøÓò |
no auto-summary | rip split-horizon | rip split-horizon | ÅäÖÃRIP V2ˮƽ·Ö¸î |
show ip protocol | display ip protocol | display ip protocol | ²é¿´Â·ÓÉÐÒé |
access-list 1-99 permit/deny IP | rule id permit source IP | rule id permit source IP | ±ê×¼·ÃÎÊ¿ØÖÆÁбí |
access-list 100-199 permit/deny protocol source IP+·´Âë destination IP+·´Âë operator operan | rule {normal|special}{permit|deny}{tcp|udp}source {<ip wild>|any}destination <ip wild>|any}[operate] | rule {normal|special}{permit|deny}{tcp|udp}source {<ip wild>|any}destination <ip wild>|any}[operate] | À©Õ¹·ÃÎÊ¿ØÖÆÁбí |
standby group-number ip virtual-ip | vrrp vrid number virtual-ip | vrrp vrid number virtual-ip | ÅäÖÃHSRP×é |
standby group-number priority | vrrp vrid number priority | vrrp vrid number priority | ÅäÖÃHSRPÓÅÏȼ¶ |
standby group-number preempt | vrrp vrid number preempt-mode | vrrp vrid number preempt-mode | ÅäÖÃHSRPÕ¼ÏÈȨ |
standby group-number track | ÅäÖö˿ڸú×Ù | ||
ip nat inside source static | nat server global <ip> [port] inside <ip> port [protocol] | nat server global <ip> [port] inside <ip> port [protocol] | ÅäÖþ²Ì¬µØÖ·×ª»» |
| »¶Ó¹âÁÙ Ñ¸Î¬Íø (https://www.chinafix.com/) | Powered by Discuz! X3.4 |
