两块9600花屏
三年宅男
2009-7-5 00:33
两块9600花屏
新手,朋友有2块9600花了,下了论坛的ATI.EXE测试了下,看不懂结果,把结果贴上来请师傅们帮忙看看,谢谢了.
1.BGA显存的9600
TEST RESULT SUMMARY:
RV350/M10 (0x4151) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1 ] Fill : FAIL
Error ID G0VB001
1024 x 768 - 16 bpp ( 60 Hz): TEST FAILURE
failing bit : MDA1 12 26
[2 ] Data line toggle (GUI) : FAIL
Error ID G0VB023
failing bit : MDA1 0 1 2 3 4 5 6 7 ...
[3 ] RW column (GUI) : FAIL
Error ID G0VB024
[4 ] RW page (GUI) : FAIL
Error ID G0VB025
failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDA1 0 1 2 3 4 5 6 7 ...
[5 ] RW channel (GUI) : FAIL
Error ID G0VB028
[6 ] Data mask : FAIL
Error ID G0VB006
1024 x 768 - 32 bpp ( 60 Hz): TEST FAILURE
[7 ] Macro + Micro8x2 tiling read : FAIL
Error ID G0VC006
[8 ] Macro + Micro4x4 tiling write : FAIL
Error ID G0VC009
[9 ] Byte swap macro+micro8x2 read : FAIL
Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write : FAIL
Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write : PASS
[12 ] Macro+Micro4x4 alignment read : PASS
[13 ] Movblit, 4 align, T : PASS
[14 ] HOST_DATA/<f,b>/M2L : PASS
[15 ] Line slopes/dir/P/solid : PASS
Failure detected.
2.TSOP的9600
RV360/M11 (0x4152) detected.
128M video memory.
[1 ] Fill : FAIL
Error ID G0VB001
failing bit : MDA0 48
Error ID G0VB023
failing bit : MDA0 16 17 18 19 20 21 22 23 ...
Error ID G0VB024
Error ID G0VB025
Error ID G0VB028
Error ID G0VB006
failing bit : MDA0 16 18 20 22 25 56 58 59 ...
Error ID G0VC006
failing bit : MDA0 8 9 10 11 16 17 18 19 ...
Error ID G0VC009
failing bit : MDA0 6 7 8 10 11 16 18 19 ...
Error ID G0VC018
failing bit : MDA0 1 2 3 4 5 6 7 8 ...
Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write : FAIL
Error ID G0VC052
failing bit : MDA0 4 8 10 11
[12 ] Macro+Micro4x4 alignment read : FAIL
Error ID G0VC057
failing bit : MDA0 4 6 8 9 10 11 33 37 ...
[13 ] Movblit, 4 align, T : FAIL
Error ID G0TR055
1024 x 768 - 16 bpp ( 75 Hz): TEST FAILURE
error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L : FAIL
Error ID G0TR014
640 x 480 - 8 bpp ( 75 Hz): TEST FAILURE
error : R051A.14 not found
640 x 480 - 15 bpp ( 75 Hz): TEST FAILURE
error : R052A.14 not found
640 x 480 - 16 bpp ( 75 Hz): TEST FAILURE
error : R053A.14 not found
640 x 480 - 32 bpp ( 75 Hz): TEST FAILURE
error : R055A.14 not found
800 x 600 - 8 bpp ( 75 Hz): TEST FAILURE
error : R061A.14 not found
800 x 600 - 15 bpp ( 75 Hz): TEST FAILURE
error : R062A.14 not found
800 x 600 - 16 bpp ( 75 Hz): TEST FAILURE
error : R063A.14 not found
800 x 600 - 32 bpp ( 75 Hz): TEST FAILURE
error : R065A.14 not found
1024 x 768 - 8 bpp ( 75 Hz): TEST FAILURE
error : R071A.14 not found
1024 x 768 - 15 bpp ( 75 Hz): TEST FAILURE
error : R072A.14 not found
error : R073A.14 not found
1024 x 768 - 32 bpp ( 75 Hz): TEST FAILURE
error : R075A.14 not found
[15 ] Line slopes/dir/P/solid : FAIL
Error ID G0TR010
error : R051A.15 not found
error : R052A.15 not found
error : R053A.15 not found
error : R055A.15 not found
error : R061A.15 not found
error : R062A.15 not found
error : R063A.15 not found
error : R065A.15 not found
error : R071A.15 not found
error : R072A.15 not found
error : R073A.15 not found
error : R075A.15 not found
Failure detected.
主板狂
2009-7-5 03:10
你得用R3MEMID来测试,你这个不对。看不懂了。
黄家成!
2009-7-5 07:40
显存芯片有问题,不过你这显卡好像没必要修了,太老了
华杰电脑
2009-7-5 14:48
这我修得多了,你把主芯片弄到BGA上加焊绝对OK
三年宅男
2009-7-5 15:30
一个说主芯片,一个说显存,该信谁的呢?
多多
2009-7-5 17:41
BGA的图片你可以先测一下最下面的那一颗显存是否空焊
无线路由器
2009-7-6 23:31
看不懂,稳当点都做一下
月饼
2009-7-7 00:06
自己换个程序再测一下。要不你就把每个数据线都打一下值吧。。。
不知道你的是大花还是小花。
