low task comd=0x00060100
into process_low_task
into LOW_TASK_U_llow task comd=0x00000110
LED timer...
LED timer...
LED timer...
LED timer...
LED timer...
LED timer...
Enter USB burn
LED timer...
Try connect time out 701, 700, 2481
mwm 0xc8836800:[0x8002023c] with [0x8002023c] ok
mwm 0xc8836800:[0x8002023c] with [0x8c42023c] ok
Hit Enter key to stop autoboot -- : 1 0
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =53f60830
copy done
Amlogic multi-dtb tool
Single dtb detected
load dtb from 0x1000000 ......
Uncompressing Kernel Image ... OK
kernel loaded at 0x01080000, end = 0x0208bb98
Loading Ramdisk to 539ff000, end 53ec8e98 ... OK
Loading Device Tree to 000000001fff0000, end 000000001ffffe2f ... OK
fdt_instaboot: no instaboot image
Starting kernel ...
uboot time: 4324011 us
[ 0.000000@0] Initializing cgroup subsys cpu
[ 0.000000@0] Initializing cgroup subsys cpuacct
[ 0.000000@0] Linux version 3.14.29-svn3593 (cq@npi2) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG MStar-1.13.1-4.9-2015.04 - MStar GCC 4.9-2015.04) ) #1 SMP PREEMPT Wed Jan 24 15:33:00 CST 2018
[ 0.000000@0] CPU: AArch64 Processor [410fd034] revision 4
[ 0.000000@0] no prop version_code
[ 0.000000@0] bootconsole [earlycon0] enabled
low task comd=0x00000003
[ 0.425546@0] pinmux-gxtvbb c1109880.pinmux: pin GPIOH_7 already requested by c1108d80.spicc; cannot claim for wifi.37
[ 0.430728@0] pinmux-gxtvbb c1109880.pinmux: pin-42 (wifi.37) status -22
[ 0.437489@0] pinmux-gxtvbb c1109880.pinmux: could not request pin 42 (GPIOH_7) from group wifi_32k_pins on device c1109880.pinmux
[ 0.449365@0] aml_wifi wifi.37: Error applying setting, reverse things back
[ 0.697465@0] mtdoops: mtd device (mtddev=name/number) must be supplied
