标题: 警告!BIOS恢复模式已被检测到,请把文件“h61ml3pr.cap到硬盘或可移动USB媒体设备... [打印本页] 作者: now520qpc 时间: 2018-11-27 16:41 标题: 警告!BIOS恢复模式已被检测到,请把文件“h61ml3pr.cap到硬盘或可移动USB媒体设备... Warning! BIOS Recovery mode has been detected, Please put the file "H61ML3PR.CAP into HDD or a removable USB media device, And restart your computer.
You can also insert ASUS Support CD to your CD-ROM and restart your computer,
if you have done these please wait a moment and don't shutdown system!!!
System will be automatically rebooted
意思是:
警告!BIOS恢复模式已被检测到,请把文件“h61ml3pr.cap到硬盘或可移动USB媒体设备,并重新启动计算机。
您也可以插入华硕支持光盘到您的光盘,并重新启动您的计算机,
如果您已经完成了这些操作,请稍候,不要关闭系统!!!
系统会自动重新启动 作者: dzy84 时间: 2018-11-27 20:26
需要恢复BIOS吧。。到官网下一个BIOS放到U盘。试试。不行就拆出来刷一下;
