Use n16v-gm-b1.
The laptop has 0.17a that cannot be triggered. I turned on the laptop and checked if the pu4503 (labeled as tps51225) schematic has tps51225c) is hot. I changed tps51225, but after heating again. After that I changed io npce285pa0dx but the same tps51225 heat.
I checked if the capacitor is shorted but not shorted.
3v and 5v capacitors, line filter check can be. No grounding
Please help me with the landlord 作者: 天意wx 时间: 2018-9-26 20:03
待机 0.17 待机偏高 51125发热 看看ldo 3V 5V 是否都正常 特别是3V 后级
