标题: 戴尔电脑电池不充电咋解决,谢谢各位老板 [打印本页] 作者: 鑫文 时间: 2018-9-10 10:43 标题: 戴尔电脑电池不充电咋解决,谢谢各位老板 The.Ac power adapter uattage and type cannot be determined.
The battery may not charge.
聪提:NGY 8&ju54he perfornance to match the pouer available.
Please connect a Del1 9o u Ac adapter or greater for the best system
performance.
riRe the Fa key (before F1 or F2 key)if you do not want to see pouwer
warning message again.
strike the F1 key to continue,F2 to run the setup utility- 作者: dlping1 时间: 2018-9-10 11:04
电脑检测到电源适配器类型不符。作者: 鑫文 时间: 2018-9-10 11:46
原配的,前几天用的好好的作者: 谢123451989 时间: 2018-9-10 12:12
