标题: 海信LED42K370 开机灰屏 背光亮的 [打印本页]
作者: 富视达眼镜 时间: 2018-7-11 08:44
经客户描述昨天看了正常关机,到第二天开机就有听到很小的广告声音,却没有图像。我拆开电视 测量主板电压 逻辑板电压都是正常,查看打印信息,这个数据我看不懂,请大神们帮我看看这打印信息吧。谢谢了!
Key1Str is Invalid key length(0) or Type(0)
Key2Str is Invalid key length(0) or Type(0)
Key3Str is Invalid key length(0) or Type(0)
Key4Str is Invalid key length(0) or Type(0)
1. Phy Mode = 5
2. Phy Mode = 5
NVM is Efuse and its size =2d[2d0-2fc]
phy mode> Error! The chip does not support 5G band 15!
RTMPSetPhyMode: channel is out of range, use first channel=1
3. Phy Mode = 9
[mAntCfgInit: primary/secondary ant 0/1
[mNICInitRT5390RFRegisters: Initialize frequency - EEPROM = 47, RF_R17 = 0
bAutoTxAgcG = 1
---> InitFrequencyCalibration
InitFrequencyCalibration: frequency offset in the EEPROM = 47
<--- InitFrequencyCalibration
MCS Set = ff ff 00 00 01
MGC_FindEnd 814: [USB] Port-2: New Dev=0xDDD0E800, proto=I bulk, wPacketSize=512.
MGC_FindEnd 817: [USB] Port-2: idVendor=0x148F, idProduct=0x5372, bcdDevice=0x0101.
MGC_FindEnd 910: [USB] Rx Ep 7 is free for use.
MGC_FindEnd 960: [USB] Rx Ep 7 prepare to use fifo at 64.
<==== rt28xx_init, Status=0
0x1300 = 00064300
RTMPAPSetInformation:: GO Intent = 7.
Opertation Channel out of range, using default.
RTMPAPSetInformation:: Op Channel = 1.
Set::OID_802_11_P2P_DEVICE_NAME
Set::OID_802_11_P2P_DEVICE_NAME DeviceName=MTK-DTV
RTMPAPSetInformation:: Device Name = MTK-DTV.
RTMPAPSetInformation:: Max Throughput out of range, using default
RTMPAPSetInformation:: Disable WFD Support!
MGC_FindEnd 814: [USB] Port-2: New Dev=0xDDD0E800, proto=O bulk, wPacketSize=512.
MGC_FindEnd 910: [USB] Tx Ep 1 is free for use.
MGC_FindEnd 960: [USB] Tx Ep 1 prepare to use fifo at 576.
UMP<2>: New session opened
Mali<2>: Session started
===>rt_ioctl_giwscan. 7(7) BSS returned, data->length = 1305
[AUD]ERROR AUD_DRVCmd AUD_CMD_AVSYNC
[VDEC]ClrDPB 0 done.
[IR] set vga pdwnc module
[SHM free]{order=3, ui4_page_num =8}
[SCPOS]vScpipUpdateDisprFreerunPrm TTDIn = 1, TTDOut = 0 $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
[SCPOS]dispmode change 0
Mali<2>: Session has ended
UMP<2>: Session closed
machine eeprom checksum ok
init: sys_prop: permission denied uid:10063 name:sys.boot_completed
MTDRVCUST_dcustom_misc_set() fail, ret=-1
[NPTV] The HDMI ColorSpace is 1
===>rt_ioctl_giwscan. 7(7) BSS returned, data->length = 1271
binder: 1231:1240 refcount change on invalid ref 218
binder: 1626:1635 refcount change on invalid ref 15
binder: 1626:1635 refcount change on invalid ref 19
binder: 1626:1635 refcount change on invalid ref 20
binder: 1972:1983 refcount change on invalid ref 9
binder: 1972:1983 refcount change on invalid ref 10
binder: 1972:1983 refcount change on invalid ref 14
init: untracked pid 2164 exited
init: untracked pid 1945 exited
==> android.process.media start
51.69 4.99
insmod: can't read '/system/lib/modules/musb_hdrc.ko': No such file or directory
Linux video capture interface: v2.00
enable logcat
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
insmod: can't insert '/system/lib/modules/fuse.ko': File exists
NTFS driver 2.1.30 [Flags: R/O MODULE].
cp: can't stat '/system/lib/modules/rfkill.ko': No such file or directory
cp: can't stat '/system/etc/wifi/udhcpd.conf': No such file or directory
cp: can't stat '/system/etc/wifi/udhcpd.leases': shell@android:/ $ init: sys_prop: permission denied uid:10065 name:vod_received_boot_completed
init: untracked pid 2181 exited
===>rt_ioctl_giwscan. 8(8) BSS returned, data->length = 1485
init: untracked pid 2590 exited
init: untracked pid 2165 exited
init: untracked pid 2564 exited
init: untracked pid 2603 exited
===>rt_ioctl_giwscan. 7(7) BSS returned, data->length = 1324
init: untracked pid 2667 exited
init: untracked pid 2592 exited
init: untracked pid 2646 exited
===>rt_ioctl_giwscan. 8(8) BSS returned, data->length = 1544
init: untracked pid 2682 exited
===>rt_ioctl_giwscan. 8(8) BSS returned, data->length = 1568
init: untracked pid 2744 exited
init: untracked pid 2669 exited
init: untracked pid 2761 exited
init: untracked pid 2721 exited
init: untracked pid 2762 exited
init: untracked pid 2820 exited
init: untracked pid 2746 exited
init: untracked pid 2795 exited
===>rt_ioctl_giwscan. 7(7) BSS returned, data->length = 1289
init: untracked pid 2837 exited
===>rt_ioctl_giwscan. 6(6) BSS returned, data->length = 1144
init: untracked pid 2895 exited
init: untracked pid 2822 exited
init: untracked pid 2869 exited
Powered by Discuz! X3.4 |
