标题: laptop turn off within a few seconds if ram inserted in dimm0 [打印本页]
作者: karnakaushal71    时间: 2018-6-23 01:49
Problem: Laptop works on only one dimm1 slot, laptop turn off within a few seconds if ram inserted in dimm0
Laptop: Dell 14r-5420 R08
Board number: DA0R08MB6E2
Counterparts was "Customers told that laptop has no issue as it is condition but  if they need to increase RAM on another slot, laptop shut down immediately....PCH need to be replaced ." "It's broken? How much you charge for that?
I told customer “how you come to know that PCH is problem?   ....reply was_ he visited repair shop and they replaced RAM, checked for corrosion even use a Multi meter to diagnose... then recommended, only go to there, where BGA Machine is Available.
          Now I received the Laptop
Get the machine, watched the appearance and inspections of the motherboard... thanks god... nowhere was touched.
Now come to the Point
dell 5420 _r08 dimm problem.pdf
484.04 KB, 下载次数: 0, 下载积分: 下载分 -2 分, 下载 1 次
Case Study
作者: 天意wx    时间: 2018-6-23 20:17
是没有写完?   欢迎外国维修朋友在论坛发帖
作者: karnakaushal71    时间: 2018-6-23 22:46
thank you very much ... need your best guidence
