标题: Graphic to non graphic [打印本页]
作者: karnakaushal71 时间: 2018-4-25 10:39
Graphicto non graphic
rubelmahmood, [06.02.18 17:32]
Graphicsto intel graphics.
Byjust removing gfx coil.
Displayautomatically switch to intel.
Noneed to remove ati chip and other components
Dothis and enjoy
UMA
THOSETHE LAPTOP MODELS WHICH ARE CONVERTING TO THE NON GRAPHIC AFTER REMOVING THEGRAPHIC SUPPLY
DELLINSPIRON 4110
HPPROBOOK P4540
HP15-R022TX
LENOVOG570
HPNOTEBOOK R53
DELLINSPIRON 5520
ACERLA-7912P
DELL3521
DELL3537
DELL3421
SONYMBX 237
HPG6 R33
LENOVOT420
LENOVOY560
LENOVOG570
HPPAVILLION DV6/DV7
BOARDPART---—
PCBHPMH-41-AB6200-D00G
PWA:HPMH-40GAB 00-D
TOCREAT INTEL BOARD
JUTREMOVE GFX COIL
PUTJUMPER IN M50 TRANSITOR IN LEG 2 TO LEG 3
THENJUST SHIFT RJ8 RESISTOR PLACE 10K AS SHOEN IN PICTURE
THENWORK WILL DONE
HP15 R series LA-A992p Dis to Uma
Justremove PLV3 and PLV2.
dellinspiron n4050 dis to uma
Justremove coil PL9201 & PU9303. No need to remove ati chip.
PU9303is just below fan connector(back side of pcb)
PL9201is near Lan Chip.
100%working .
lenovoG500s dis to uma
G500sdis to uma
PL803- remove
Dell5520 LA-8241P Dis to Uma
Onlyremove gfx coil PL800 and done
LenovoG770 LA-6758P
movea resistor R702 to the position of R707 , and a resistor R703 to the positionof R705.
HP-15R62 DIS TO UMA
PCB-DA0R62MB6E1REV:E
Justremove 2 coil PL20 nd PL23 100%
mbx-276without
jUSTREMOVE THE GFX COIL
DELLINSPIRON 4110
TOMAKE NON-GRAPHIC JUST REMOVE THE GRAPHIC SUPPLY COIL
ITWILL WORK
CONVERTTO UMA BY REMOVING GFX SUPPLY
THELIST OF THOSE MODELS WHICH WE CAN EASLLY CONVERT TO THE UMA AFTER REMOVING THEGRAPHICS SUPPLY COIL ....
LENOVOG500S
HP431
DELL5520
SONYMBX-239
LENOVOG580
HPNOTEBOOK R53
DELL3521
DELL411O
HPPROBOOK P4540
LENOVOT420,Y560,G570,Z570
HPDM4-3000
LENOVOU460
LENOVO IDEAPAD S510P
MODELLENOVO IDEAPAD S510P TOUCH 20299
MOTHERBOARDMODEL LS41P MB 12293-1 48.4L106.011
REMOVEPL8201 AND PL8202 ONLY
HPG6 Quanta R23 with discrete on UMA
QuantaR23
Movethe R836 in position R837
RemoveR123 R121 + pc100 close or you can simply delete PL22
MoveR369 to position R368
SamsungT09-305V5A
Todisable the discrete graphics, enough to remove one resistor, R831
SONY MBX-239 NON GRAPHICS CONVERSION Topic is solved
TOCONVERT SONY MBX-239 MOTHERBOARD JUST REMOVE GRAPHICS VOLT COIL ONLY ITS DUALSUPPORTED MOTHERBOARD .
Dv7-6c54eris it possible to convert uma
amdor intel in both cases this mb comes with dual graphic card just remove graphicchip supply its works
DellInspiron 14R N4050
REMOVEGFX SUPPLY
HPpavilion G6 UMA conversion
Themost simplest conversion.
DA0R33MB6D0REV D (R33)
RemovePL27
Remove R550 and place @ R549
That's it
UMA
THOSE THE LAPTOP MODELS WHICH ARE CONVERTING TO THE NON GRAPHIC AFTER REMOVING THE GRAPHIC SUPPLY
DELL INSPIRON 4110
HP PROBOOK P4540
HP 15-R022TX
LENOVO G570
HP NOTEBOOK R53
DELL INSPIRON 5520
ACER LA-7912P
DELL 3521
DELL 3537
DELL 3421
SONY MBX 237
HP G6 R33
LENOVO T420
LENOVO Y560
LENOVO G570
G580 conversation dis to uma
G580 MB no lg4858 only pl9201 qoil open and nvidia IC open display come good job
DELL INSPIRON 5520 CONVERT TO UMA
TO CONVERT TO UMA JUST REMOVE THE GFX SUPPLY COIL
Hp 431 Without graphic
We can convert hp 431 Ati
Graphics to intel graphics.
By just removing gfx coil.
Display automatically switch to intel.
No need to remove ati chip and other components
Do this and enjoy
HP Pavilion 17-e033er (Quanta r75) alteration of Discrete in the UMA Topic is solved
IF ANY ONE HAVING THIS TYPE MOTHERBOARD.PLEASE TRY FOLLOWING METHOD TO CONVERT DIS TO UMA. I AM NOT HAVING THIS BOARD.I GOT IT FROM ONLINE.
Remaking a UMA simple move one strap: Remove R489 (10k)> put R501 (10k)
Located next to the FCH
Rubel mahmood, [06.02.18 17:32]
Acer three models Graphic To non Grapchics convert Topic is solved
Below listed Acer laptop motherboard can be converted to Graphics to non Graphics
To do so we just need to remove Graphics ic's Coile only
But to reduce power consumption remove graphic ic's power supply components it is not necessary to remove them if you don't bother about power consumption
You can use this Convert Graphic To non Graphics techniques of removing Graphic ic's supply coile
In every laptop which has switchable Graphics feature
Switchable Graphics means when you go in to WINDOWS and you can see two graphic drivers running at the same time in device manager > Display adapter tab
LA-7912p
LA-6901P
LA-9535P
Powered by Discuz! X3.4 |
