IC Code and Equivalent
karnakaushal71
2018-4-5 12:20
DJ= - RT8202AGQW
DJ- - RT8202APQW
DK- - RT8204PQW WQFN 3x3-16
JL= - RT8204AGQW WQFN 3x3-16
FR= - RT8204BGQW WQFN 3x3-16
H6= - RT8204CGQW WQFN 3x3-16
CJ= - RT8205AGQW
CK= - RT8205BGQW
CL= - RT8205CGQW
CB= - RT8205DGQW
DT= - RT8205EGQW
EM= - RT8205LGQW [RT8205AGQW]
EN= - RT8205MGQW [RT8205CGQW]
CP= - RT8207GQW
DH= - RT8207AGQW
EF= - RT8207LGQW
J7= - RT8207MGQW
DS= - RT8223BGQW LDO Output: 70mA
11= - RT8223NGQW LDO Output: 100mA [RT8223BGQW]
20 - RT8223PZQW LDO Output: 100mA [RT8223BGQW]
EP= - RT8223LGQW LDO Output: 100mA [RT8223AGQW]
EQ= - RT8223MGQW LDO Output: 100mA [RT8223BGQW]
FF= - RT8208AGQW
FG= - RT8208BGQW
H8= - RT8208DGQW
30= - RT8208EGQW
31= - RT8208FGQW
FH= - RT8209AGQW WQFN-16L 3x3
A0= - RT8209BGQW WQFN-14L 3.5x3.5
A3= - RT8209EGQW WQFN-14L 3.5x3.5
JX= - RT8209LGQW WQFN-16L 3x3
A8= - RT8209MGQW WQFN-14L 3.5x3.5
K0= - RT8209NGQW
A6= - RT8209PGQW
EL= - RT8015A
DZ= - RT8113
CZ= - RT8561AGQW
RT8202=RT8209
RT8204=G5601
RT8205B=TPS51125=TPS51123=G5608=up6182=RT8223P
RT8206B=ISL6237=TPS51427
RT8206A=ISL6236=PM6686=SN0608098
RT8207=TPS51116 (TON resistor on pin12, check datasheet)
RT8208B=SC411
RT8209B=TPS51117=UP6111
RT9025=G966-25=UP7704
RT9018B=G9661-25=UP7706
MAX8778=MAX17020
MAX8724=MAX1908=MAX8765
MAX8725=MAX1909
APW7138=ISL6268
APW7108=ISL6227=FAN5236
APL5913=APL5930
laptop ic equivalent
TPS51117=RT8209B RT8209A
Ao=ca AO=BM AO=CD AO=CA AO=BG AO=BG AO=CB AO=BL. AO=BG AO=BH FH=CG CU1 FH=EE FH=CC FH=DD FH=CL FH=8JFH=CF
TPS51123=RT8223M=UP1585QQAG RT8223BGQW RT8223B rt8223m
el=20 eq=cg eq=dm,eq=do eq=dd=da=dc=dk DS=CC DS=CD DS=CE DS=CF DS=BJ DS=BK
RT8205A=TPS51125 RT8205B=UP6182=RT8223
U1585QQAG=51123A=RT8223P
EM=EC EQ=XX
ISL6251 = G5209
ISL6237 MAX17020 MAX8778 TPS51427 RT8206B PM6686 SN608090
PM6686=TPS17020=isl6236=RT8206a=ISL62366
TPS51116=RT8207 ISL6227=APW7108 DH=CH DH=CA CP=DD CP=CF DH=EA CP=AJ
MAX8734A=RT8203
MAX1908=MAX8724
ISL88731=BQ24745
ISL6266=ISL6262
RT8204C= RT8204BGQW H6=CH H6=CB H6=CG H6=BE H6=CC FR=AH FR=AM
UP1585QQAG=TPS51123A=RT8223P DS=CC DS=CD DS=CE DS=CF DS=BJ DS=BK
KB9206QFC0 KB9206QFD2 KB9206QFD3
RT8207LGQW EF=CM EF=CG EF=CF EF EF=CM EF=DG EF=DE EF=CG EF=DF
RT8209A FH=CG FH=EE FH=CC FH=DD FH=CL FH=8J FH=CF
TPS51125A=RT8205BGQW CK=CD
RT9018B ES=EF ES=CL ES=DD
RT8207LGQW EF=DE
SN10504=SN0608098
MAX1908=MAX8724
ALC660=ALC883
ISL62883=ISL62882
IT8500E =IT8512E = IT8502E
P2805MF=G5933
Richtek laptop ic code
DJ= – RT8202AGQW
DJ- – RT8202APQW
DK- – RT8204PQW
JL= – RT8204AGQW
FR= – RT8204BGQW
H6= – RT8204CGQW
CJ= – RT8205AGQW
CK= – RT8205BGQW
CL= – RT8205CGQW
CB= – RT8205DGQW
DT= – RT8205EGQW
EM= – RT8205LGQW
EN= – RT8205MGQW
CP= – RT8207GQW
DH= – RT8207AGQW
EF= – RT8207LGQW
J7= – RT8207MGQW
DS= – RT8223BGQW
11= – RT8223NGQW
20 – RT8223PZQW
EP= – RT8223LGQW
EQ= – RT8223MGQW
FF= – RT8208AGQW
FG= – RT8208BGQW
H8= – RT8208DGQW
30= – RT8208EGQW
31= – RT8208FGQW
FH= – RT8209AGQW
A0= – RT8209BGQW
A3= – RT8209EGQW
JX= – RT8209LGQW
A8= – RT8209MGQW
K0= – RT8209NGQW
A6= – RT8209PGQW
EL= – RT8015A
DZ= – RT8113
CZ= – RT8561AGQW
D9= – RT9716AGQW
C7= – RT9293-20
wangRenJun
2018-4-8 10:35
感谢楼主的精心的整理和分享,已收藏
