查看: 2547|回复: 15
[显卡维修]
现在还有人修9550花屏吗?12块花屏!
发表于 2009-6-17 11:46:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式 �
去收了一批二手电脑,哪知道,有12块显卡全是花的。。
从小花到大花,全部都有。。。
用R3测试,看不懂,希望高手帮忙看看。。
翔升雷神 9550专业
=================以下是R3信息=================================
R3MEMID version 1.10, (c) Copyright ATI Technologies Inc, 2004
Log file generation enabled to .\R3MEMID.LOG ...
Extended logging enabled ...
Reference data file (RDF) loading disabled ...
Failing bits in test [1] Fill
  errcount: 552850
  MDA0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  MDB0: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [2] Data line toggle (GUI)
  errcount: 250369
Failing bits in test [3] RW column (GUI)
  errcount: 277369
Failing bits in test [4] RW page (GUI)
  errcount: 277369
Failing bits in test [5] RW channel (GUI)
  errcount: 277369
Failing bits in test [6] Data mask
  errcount: 554738
Failing bits in test [7] Macro + Micro8x2 tiling read
  errcount: 88271
Failing bits in test [8] Macro + Micro4x4 tiling write
  errcount: 88807
Failing bits in test [9] Byte swap macro+micro8x2 read
  errcount: 552777
Failing bits in test [10] Byte swap macro+micro4x4 write
  errcount: 553299
Failing bits in test [11] Marco+Micro8x2 alignment write
  errcount: 1239
  MDB0: 16 17 18 20 22 23
Failing bits in test [12] Macro+Micro4x4 alignment read
  errcount: 1239
TEST RESULT SUMMARY:
RV350/M10 (0x4153) detected.
128M video memory.
Test suite ran 1 of 1 times.
Checking test status array ...
[1  ] Fill                                                : FAIL
    Error ID G0VB001
  1024 x  768 - 32 bpp ( 60 Hz): TEST FAILURE
    failing bit : MDA0 0 1 2 3 4 5 6 7 ... MDB0 0 1 2 3 4 5 6 7 ...
[2  ] Data line toggle (GUI)                              : FAIL
    Error ID G0VB023
[3  ] RW column (GUI)                                     : FAIL
    Error ID G0VB024
[4  ] RW page (GUI)                                       : FAIL
    Error ID G0VB025
[5  ] RW channel (GUI)                                    : FAIL
    Error ID G0VB028
[6  ] Data mask                                           : FAIL
    Error ID G0VB006
[7  ] Macro + Micro8x2 tiling read                        : FAIL
    Error ID G0VC006
[8  ] Macro + Micro4x4 tiling write                       : FAIL
    Error ID G0VC009
[9  ] Byte swap macro+micro8x2 read                       : FAIL
    Error ID G0VC018
[10 ] Byte swap macro+micro4x4 write                      : FAIL
    Error ID G0VC021
[11 ] Marco+Micro8x2 alignment write                      : FAIL
    Error ID G0VC052
    failing bit : MDB0 16 17 18 20 22 23
[12 ] Macro+Micro4x4 alignment read                       : FAIL
    Error ID G0VC057
[13 ] Movblit, 4 align, T                                 : FAIL
    Error ID G0TR055
  1024 x  768 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R073A.13 not found
[14 ] HOST_DATA/<f,b>/M2L                                 : FAIL
    Error ID G0TR014
   640 x  480 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R051A.14 not found
   640 x  480 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R052A.14 not found
   640 x  480 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R053A.14 not found
   640 x  480 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R055A.14 not found
   800 x  600 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R061A.14 not found
   800 x  600 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R062A.14 not found
   800 x  600 - 16 bpp ( 75 Hz): TEST FAILURE
     error : R063A.14 not found
   800 x  600 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R065A.14 not found
  1024 x  768 -  8 bpp ( 75 Hz): TEST FAILURE
     error : R071A.14 not found
  1024 x  768 - 15 bpp ( 75 Hz): TEST FAILURE
     error : R072A.14 not found
     error : R073A.14 not found
  1024 x  768 - 32 bpp ( 75 Hz): TEST FAILURE
     error : R075A.14 not found
[15 ] Line slopes/dir/P/solid                             : FAIL
    Error ID G0TR010
     error : R051A.15 not found
     error : R052A.15 not found
     error : R053A.15 not found
     error : R055A.15 not found
     error : R061A.15 not found
     error : R062A.15 not found
     error : R063A.15 not found
     error : R065A.15 not found
     error : R071A.15 not found
     error : R072A.15 not found
     error : R073A.15 not found
     error : R075A.15 not found
Failure detected.
发表于 2009-6-17 12:03:20 | 只看该作者 �
只要有钱一定有人修的,
发表于 2009-6-17 12:21:21 | 只看该作者 �
我测试了N块,反馈的信息好像都是一样,,到底是软件有问题还是,哪里有问题??
(我的R3是1。10版本的好像,,高的版本找不到,,哎!)
128M video memory.
[1  ] Fill                                                : FAIL
    Error ID G0VB001
    Error ID G0VB023
    Error ID G0VB024
    Error ID G0VB025
    Error ID G0VB028
    Error ID G0VB006
    Error ID G0VC006
    Error ID G0VC009
    Error ID G0VC018
    Error ID G0VC021
    Error ID G0VC052
    Error ID G0VC057
发表于 2009-6-17 13:24:07 | 只看该作者 �
如果你没动过可以发给我,如果动过我不接。。
PS:GPU没动过的
发表于 2009-6-17 16:22:28 | 只看该作者 �
老大,能不能教一下,怎么修啊,,上面的信息大概是什么意思??
发要发到杭州去吗??修一块,费用要多少?
发表于 2009-6-17 20:44:24 | 只看该作者 �
呵呵  出银子肯定有修的的喽
发表于 2009-6-18 00:33:21 | 只看该作者 �
全报错啊。电压对不对哦。。没动过可以发来。杭州西湖区文三路文三数码大厦1215室。不保证一定修复。
收件人:李向阳 电话 0571  86981106
发表于 2009-6-18 00:52:22 | 只看该作者 �
9550维修是最大的,也是资料相对最多的,你要是不懂修就送修得了,不然全完了可不好啊。论坛上有好多9550的贴子,你可以参考的。
发表于 2009-6-18 01:33:52 | 只看该作者 �
收件人:孙景轩 电话 0571  86981106
月饼 发表于 2009-6-18 00:33
9550如果是A B通道0--7最好备几个GPU要不然恐怕很难搞好,他的卡多你可以给他拼一下,这些我今天没事的时候特意把以前的卡拿出来验证了。
头像被屏蔽
10#
发表于 2009-6-18 01:49:02 | 只看该作者 �
你们一看到有生意就都抢着来了,什么时候我也能参合进去啊
发表于 2009-6-18 10:16:14 | 只看该作者 �
我拿没花的卡测试,,好像也会出现
全是FAIL。。
我主板也换过了。。到底是什么问题啊,,软件问题吗??
是不是正常的话,,全是PASS,,有问题全是 FAIL的??
发表于 2009-6-18 12:13:34 | 只看该作者 �
不好说,如果可以正常使用你就别钻牛角尖了
发表于 2009-6-18 14:10:13 | 只看该作者 �
正常使用哪个  管他报不报错
发表于 2009-6-21 17:30:12 | 只看该作者 �
花屏的显卡真多,但也不一定花屏的都是GPU的错吧,显存也会引起花屏的。
发表于 2009-6-21 21:08:15 | 只看该作者 �
最主要的是要针对方案来维修
发表于 2009-7-12 14:19:01 | 只看该作者 �
你想修的话可以发给我,25元一片,修复率百分之90以上,我的电话:13764738183
