标题: mac mini a1176固件升级至2.1支持4gb内存 [打印本页]
作者: xincity2019    时间: 2017-12-18 08:23
操作教程:
下载附件,保存至路径、/System/Library/CoreServices/Firmware Updates
                需要解压。保存到路径,
运行终端:以下命令,逐一执行。
janitors-Mac-mini:~ id$ open "/System/Library/CoreServices/Firmware Updates"
* cp the 2 files to:
janitors-Mac-mini:~ id$ cd "/System/Library/CoreServices/Firmware Updates"
* relax the file permissions, (world-readable) so the files can be seen at boot-time
chmod -R 777 "/System/Library/CoreServices/Firmware Updates/*"
* run cmd
janitors-Mac-mini:~ id$ sudo bless -mount / -firmware /System/Library/CoreServices/Firmware\ Updates/EFIUpdaterApp.efi -payload /System/Library/CoreServices/Firmware\ Updates/LOCKED_MM11_0055_08B.fd -options "-x efi-apple-payload0-data" --verbose
完成后,一大串提示成功了。
return 0
重启长按开机键,即可成功。
进入升级固件状态,
作者: xincity2019    时间: 2017-12-18 08:25
1楼的需要解压的附件,此处下载。全网独家下载。感谢使用,纪实反馈 106_890964_11bdf68db19d534.zip (1.15 MB, 下载次数: 16)
