MITAC 7233 产品
对应联想机型:15XX系列 跳线开关名称:SW2
SWITCH(SW2) 1 2 3 LCD 类型
ON ON ON 13.3 HITACHI TX34D61VC1HAD
OFF ON ON 12.1 MITSUBISHI 12。1 AA121SJ03
ON OFF ON 13.1 HYUNDAI HT13X14
OFF OFF ON 12.1 SANYO TM121SV-02L01
ON ON OFF 12.1 SANYO TM121SV-02L03(LVDS)12.1 MITSUBISHI 12.1 AA121SJ23
OFF ON OFF 12.1 SANYO HPA LM-JK63-22NTR
ON OFF OFF 12.1 SHARP LQ 12S1LH12
OFF OFF OFF 12.1 DSTN SR120522NTR
E600
内存第二个插槽处有个的跳线:J4(cmos_clr),找个镊子短接那两点一到两秒就行了!
T600
This section provides an easy step in doing system upgrades for your notebook computer.
Jumper Settings (For M285 / M288 Model)
This section provides a jumper setting lists of configuring the notebook.
Figure 2-5 Switch 5 Jumper Setting
Keyboard Type Select ( SW5 )
K/B Type Pos #1 POS #2
US KEYBOARD OFF OFF
RESERVE OFF ON
JP KEYBOARD ON OFF
UK KEYBOARD ON ON
Logo Select ( SW5 )
Logo Pos #3
RESERVE OFF
RESERVE ON
Password Override ( CMOS / RTC Data ) Jumper Setting
Password Override Pos#4
Password Normal OFF
Clear Password ON
i Before doing password override, take off AC adapter and battery first.
Main Board ID Select
Main Board ID Pos #5 POS #6
PCMCIA USE INTA# OFF OFF
RESERVE OFF ON
PCMCIA USE INTB# ON OFF
RESERVE ON ON
CD-ROM Master / Slave Select
CD-ROM Pos #7
RESERVE OFF
RESERVE ON
CMOS Clear Select
CD-ROM Pos #8
Normal OFF
Clear CMOS ON
i Pos # 8 is N/A Pin for reserve
2.3.2 Jumper Setting
SW6 / CPU VID SELECT (Only for M288 Model)
Figure 2-6 Switch 6 Jumper Setting
Processor Pins
PIN5 PIN4 PIN3 PIN2 PIN1 Vcc_max
OFF OFF OFF OFF OFF VRM output off
OFF OFF OFF OFF ON 1.100
OFF OFF OFF ON OFF 1.125
OFF OFF OFF ON ON 1.150
OFF OFF ON OFF OFF 1.175
OFF OFF ON OFF ON 1.200
OFF OFF ON ON OFF 1.225
OFF OFF ON ON ON 1.250
OFF ON OFF OFF OFF 1.275
OFF ON OFF OFF ON 1.300
OFF ON OFF ON OFF 1.325
OFF ON OFF ON ON 1.350
OFF ON ON OFF OFF 1.375
OFF ON ON OFF ON 1.400
OFF ON ON ON OFF 1.425
OFF ON ON ON ON 1.450
ON OFF OFF OFF OFF 1.475
ON OFF OFF OFF ON 1.500
ON OFF OFF ON OFF 1.525
ON OFF OFF ON ON 1.550
ON OFF ON OFF OFF 1.575
ON OFF ON OFF ON 1.600
ON OFF ON ON OFF 1.625
ON OFF ON ON ON 1.650
ON ON OFF OFF OFF 1.675
ON ON OFF OFF ON 1.700
ON ON OFF ON OFF 1.725
ON ON OFF ON ON 1.750
ON ON ON OFF OFF 1.775
ON ON ON OFF ON 1.800
ON ON ON ON OFF 1.825
ON ON ON ON ON 1.850
V21
CPU跳线作者: 许冠杰 时间: 2009-6-7 23:25
K6系列
Jumper Settings
US KEYBOARD OFF OFF
RESERVE OFF ON
JP KEYBOARD ON OFF
UK KEYBOARD ON ON
Logo Select
Logo Pos #3
RESERVE OFF
RESERVE ON
RTC Battery Normal OFF
Clear (RTC) DATA ON
RESERVE OFF
RESERVE ON
CD-ROM Pos #6
Master ON
Slave OFF
S60
CHKPW
DISABLE ENABLE
SW1-3 ON OFF
V71:
1:MODEM卡下面两焊点
K70:
Jumper Settings
US KEYBOARD OFF OFF
RESERVE OFF ON
JP KEYBOARD ON OFF
UK KEYBOARD ON ON
Logo Select ( SW5 )
Logo Pos #3
RESERVE OFF
RESERVE ON
69系列
Jumper Settings
This section provides a jumper setting lists of configuring the notebook. The jumper switches are near the memory socket. To access the jumper switches, you may refer to section 2.3.3 for procedures on how to access memory socket.
For CPU with SpeedStep (Geyserville) technology
Pos#1 Pos#2 Pos#3 Pos#4 Pos#5 Pos#6
PIII 600 / 500MHz
SW4 On On On On Off On
SW5 Off On Off Off NC NC
PIII 650 / 500MHz
For CPU without SpeedStep (Geyserville) technology
PIII 450MHz
SW4 On Off Off Off Off Off
SW5 On On On Off NC NC
PIII 500MHz
Celeron 450MHz
Celeron 500MHz
CPU Core Voltage Jumper Setting
Low VoltageHigh Voltage SW5-#1SW4-#2 SW5-#2SW4-#3 SW5-#3SW4-#4 SW5-#4SW4-#5 SW4-#1SW4-#6
0.00v Off Off Off Off On
1.30v On Off Off Off On
1.35v Off On Off Off On
1.40v On On Off Off On
1.45v Off Off On Off On
1.50v On Off On Off On
1.55v Off On On Off On
1.60v On On On Off On
1.65v Off Off Off On On
1.70v On Off Off On On
1.75v Off On Off On On
1.80v On On Off On On
1.85v Off Off On On On
1.90v On Off On On On
1.95v Off On On On On
2.00v On On On On On
Vcore_det Jumper Setting (SW6)
Sw6 Pos#3
FC-PGA Processor On
Micro-PGA2 Processor Off
Logo Selection Setting (SW6)
Logo Selection Pos#1 Pos#2
No Logo Off Off
Reserved On Off
Reserved Off On
Reserved On On
BIOS Selection Setting (SW6)
Machine model Pos#3
A450 Off
A430 On
Keyboard Type Selection Setting (SW6)
Keyboard Type Pos#4 Pos#5
US Off Off
Japan On Off
Reserved Off On
UK On On
Password Override (CMOS/RTC Data) Jumper Setting (SW6)
SW6 Pos#6
RTC Battery Normal Off
Clear (RTC) DATA On
Password Override ( CMOS / RTC Data ) Jumper Setting ( SW5 )
Password Normal OFF
Clear Password ON
Main Board ID Select ( SW5 )
RESERVE OFF ON
RESERVE ON ON
CD-ROM Master / Slave Select ( SW5 )
CD-ROM Pos #7
RESERVE OFF
RESERVE ON
L510
:打开键盘可以看到BIOS电池,拔掉BIOS电源线,即可。Please find the switch on Mianboard near printer connecter & audio DJ
connecter, mover the switch 1 to ON, then will by pass BIOS checking.
510 硬盘密码的问题,出于安全考虑,如果忘了,就要换硬盘,所以,务必要求客户牢记密码。
V80:
V31
Jumper Settings
Switch 1
K/B Type Pos #2 POS #3
US KEYBOARD OFF OFF
RESERVE OFF ON
JP KEYBOARD ON OFF
UK KEYBOARD ON ON
DVDSEL
Logo Pos #1
Select CD-ROM OFF
Select DVD ON
Clear (RTC) DATA ON
