标题: K670D-G4D1进水不开机 [打印本页]
作者: 474673470 时间: 2017-7-13 12:14
标题: K670D-G4D1进水不开机
k670d进水如图51125进水直接换一个 换后测量各电感3 5V 短路 直接烧机发现 U24 和南桥坏 更换后可以开机但是开机慢在XX宝买一个原厂BIOS后搞定file:///c:/users/administrator/appdata/roaming/360se6/User Data/Temp/forum.php?mod=image&aid=1535802&size=300x300&key=fbe0c5408c5d2ae1&nocache=yes&type=fixnonefile:///c:/users/administrator/appdata/roaming/360se6/User Data/Temp/forum.php?mod=image&aid=1535802&size=300x300&key=fbe0c5408c5d2ae1&nocache=yes&type=fixnone
6-71-W65K0-d02.pdf
(4.86 MB, 下载次数: 86)
